Post new topic Reply to topic  [ 267 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 18  Next
The NetEA Codex list. How do you feel about it? A few Qs
 Post subject: Re: The NetEA Codex list. How do you feel about it? A few Qs
PostPosted: Mon Nov 24, 2014 3:09 pm
Hi Jim. In the spirit of discussion, perhaps you could explain further why these changes should be adopted.
PostPosted: Mon Nov 24, 2014 3:13 pm
JimXII wrote:
A unit of marauder bombers or a Thunder hawk can place a bm nicely. And are both more than just one trick ponies.
They can, by accepting risk. And indeed the enemy deployment zone turn 1 is normally the worse place to fly airplanes due to the flak. But a nice bombardment removes those hydra or similar and let the thunderhawks fly in...
PostPosted: Mon Nov 24, 2014 3:16 pm
And both can be countered, whirlwinds with init 1 SR 5 are likely to go first and automatically activate then hitting with 2 templates on 3s and 4's. Would be absolutely fantastic in conjunction with Teleporting terminators or air assaults, and absolutely lethal to any other artillery or fragile vehicle formations
www.epic-uk.co.uk
PostPosted: Mon Nov 24, 2014 4:09 pm
JimXII wrote:
It aligns perfectly with fluff and wont overpower a still relatively expensive and niche marine support option.
Jim
Whirlwinds are specifically light, highly mobile artillery which sacrifice the range and hitting power of Imperial Guard artillery for speed and ease of transportation.
Additionally, as 40k is more or less World War II IN SPACE, I will point out that traditional heavy tube artillery outranged rocket artillery two to three times.
PostPosted: Mon Nov 24, 2014 5:59 pm
From my pov, WW are usually kill #1 for my opponent's air force/artillery. I've stopped using them because 1xAA4+ shot from a hunter or two isn't enough to stop them from being reduced to a pointless inclusion.
PostPosted: Mon Nov 24, 2014 6:42 pm
Aye they can be #1 target. That's also though an air sorte that's not blowing something else important up however. I think the ability to pad the formation might help some as well as the PPU being reevaluated.
PostPosted: Mon Nov 24, 2014 6:46 pm
Agreed Dobbsy which is why using multiples makes sense. And spamming WW with 120 cm range would be even more lethal. And with no restriction, I would be amongst the first to try six or more such formations to back up some scouts bikes and land speeders. Heck I might even try that as they are :D
PostPosted: Mon Nov 24, 2014 8:43 pm
Here you go Ginger ;)
WHIRLWIND [375]
4 Whirlwinds, Hunter
WHIRLWIND [375]
WHIRLWIND [300]
4 Whirlwinds
WHIRLWIND [300]
4 Whirlwinds
WHIRLWIND [300]
4 Whirlwinds
WHIRLWIND [300]
4 Whirlwinds
TERMINATOR [400]
4 Terminator units, Chaplain
THUNDERHAWK [200]
1 Thunderhawk gunship
SCOUT [150]
4 Scouts plus Transport
SCOUT [150]
SCOUT [150]
@MephistonAG for all sorts of twitter madness
PostPosted: Mon Nov 24, 2014 8:51 pm
Sounds about right Meph - any takers . . . ? ;D
PostPosted: Mon Nov 24, 2014 9:18 pm
So this list would use 120cm range WW?
PostPosted: Mon Nov 24, 2014 9:23 pm
God no! :D
Ginger likes to push the envelope!
PostPosted: Mon Nov 24, 2014 9:25 pm
When you're pushing the envelope, just remember folks, that's where the stamp gets canceled ;)
[roughly paraphrased fighter jock saying]
PostPosted: Mon Nov 24, 2014 10:11 pm
If you put WWs in they are important to your game plan :)
Pad it with an extra vehicle? Drop the points on the 4?
PostPosted: Mon Nov 24, 2014 10:44 pm
6 Strong WW with a Hunter have worked well for me twice in the Iron Hands. Of course we also don't have teleporting termies so there's some balance on that on the units themselves.
I agree that if you're taking them as a disposable unit, they're too expensive. They're at the magical junction of just strong enough to not ignore but too expensive to throw away either.
In a 3k game there's just more important things to handle unless you totally "get on the bus" like occurred in the EEC. Totally different story at 5k. They're probably fine as is but a single formation is not going to cut it; They like friends ;).
PostPosted: Mon Nov 24, 2014 11:42 pm
If WWs are important to your game plan, bring 2 fms.
- Ulrik
