[BatRep] Necrons End-of-May Battle 3
 Post subject: [BatRep] Necrons End-of-May Battle 3
PostPosted: Fri May 26, 2006 1:36 pm
Machines vs Machinez!
PostPosted: Fri May 26, 2006 5:53 pm
Rules Used
All experimental rules
Necrons 4.0
OGBM 1.7
Armies
The Great Despair - 2470 points
Tomb Complex
Phalanx 1
1 Pariah
Phalanx 2
1 Pariah
Phalanx 3
1 Pariah
Equus 1
6 Heavy Destroyers
Equus 2 - (BTS Goal)
6 Heavy Destroyers
1 Lord
Monolith 1
1 Obelisk
Monolith 2
1 Obelisk
Monolith 3
1 Obelisk
Pylon
C'tan, The Deceiver
Da Wreckin' Krew - 2500 points
'Eadsmacka - (BTS Goal)
Gargant
3x Soopa Guns
1 Big Mek
Extra Power Fields
8 Power Fields
Spinecutta
Kustom Gargant
Ripper Fist
1 Big Mek
Reinforced Boilers
2 Power Fields
Da Kannon
Big Krawla
1 Big Mek
1 Mega Kannon replaces both Mega-Choppas
5 Power Fields
Big Booma
Blasta Gargant
1 Big Mek
Reinforced Boilers
1 Power Field
Rollin' Thunda
Fortress Mob
1 Gunfortress
1 Big Mek
Grot Targetters
Gitgrinda
Fortress Mob
1 Gunfortress
1 Big Mek
Grot Targetters
PostPosted: Fri May 26, 2006 6:39 pm
Setup
4x4 table
OGBM chose corner deployment.
Garrisons and Deployment
Necrons kept Monoliths 2 and 3, Phalanx 3, and The Deceiver in reserve.
Necrons garrisoned Phalanxes 1 and 2 on overwatch and in cover.
Remaining deployment as shown.
PostPosted: Fri May 26, 2006 7:04 pm
Turn 1
Monolith 2 appears near OGBM Objective 2 and gets a Blast marker.
Strategy roll: Necrons
The Pylon hums and sustains fire on the Blasta Gargant? hitting a nearby tree instead.
Eques 1 doubles on the Kustom Gargant, stripping away both Power Fields.
The Blasta Gargant sustains fire (successfully!) on Eques 2, scrapping 4 Heavy Destroyers and easily breaking the formation.
Gunfortress 2 doubles towards Monolith 2, placing a Blast Marker and breaking the formation.
Phalanx 3 issues forth from Monolith 2's Portal to engage Gunfortress 2, they destroy the Ork war machine, but lose their Pariah in the fight.
The Kustom Gargant doubles up to Eques 1 and obliterates 2 Heavy Destroyers.
Phalanx 1 doubles towards the Kustom Gargant, firing ineffectively.
The Gargant saunters up on a double, blasting both Eques 1 and Phalanx 2, the Heavy Destroyers are wiped out, with thanks to the Gaze of Mork, and the Phalanx loses 1 Necron Warrior.
Gunfortess 1 drives up to Phalanx 1 and places a single Blast marker.
Phalanx 2 doubles out of the ruined cathedral to ineffectively fire on Gunfortress 1.
The Big Krawla rumbles forward on a double, and blasts 3 Warriors out of Phalanx 1, breaking the formation.
End of turn: All broken Necron formations fade away.
Only Gunfortress 1 fails to rally for the Orks.
(This shot combines the End of Turn and the Necron teleports from Turn 2)
PostPosted: Fri May 26, 2006 7:18 pm
Turn 2
Monolith 3 and The Deceiver show up right beside the Blasta Gargant!
Monolith 3 sustains fire on the Blasta Gargant, knocking down a Power Field.
With a strange laugh, The Deceiver engages the Blasta Gargant and does 4DC of damage, forcing the lumbering machine away.
The Gargant advances on Monolith 3 blasting away a single Obelisk, but also catching The Deceiver in the blast, breaking both formations.
The Big Krawla holds its ground and then sustains fire on Phalanx to grinding up 4 Warriors, 1 with the Necron Lord, and the Pariah.
Eques 2 marshals out of the Portal of Monolith 3, and restores all 4 missing Heavy Destroyers!
Monolith 1 advances on Gunfortress 1, popping up to destroy it with a critical hit.
The Kustom Gargant doubles on Eques 2, and re-scraps 3 of the restored Heavy Destroyers.
Phalanx 1 marshals out of Monolith 1 and rebuilds 4 Necron Warriors.
Phalanx 3 goes onto overwatch, guarding OGBM Objective 2.
The Pylon sustains fire on the Krawla and strips away 3 Power Fields!
All Ork formations rally.
PostPosted: Fri May 26, 2006 7:54 pm
Turn 3
Monolith 2 and The Deceiver again go after the Blasta Gargant!
Strategy roll: OGBM
The Kustom Gargant barrels through the woods on a double and lays waste to Monolith 2, leaving nothing by dead metal behind.
The Krawla stays dug in and sustains fire on Phalanx 1 demolishing 5 Necron Warriors, including the Necron Lord!
Still Laughing, The Deciever rips into the Blasta Gargant, doing 1DC of damage and receiving 2DC in return. ?Despite this, the Star God wins, though both formations break.
The Pylon again sustains fire on the Krawla, knocking down the 2 remaining Power Fields, doing 1DC of damage, as well as starting a fire.
Again the Gargant moves towards Monolith 3 on a double, doing no damage, but breaking the formation? which moves closer!
Phalanx 2 marshals out of Monolith 3, with 3 Warriors, plus the Lord, repaired.
Eques 2 marshals out of Monolith 1, taking OGBM Objective 1, and again rebuilding all 3 missing Heavy Destroyers.
Phalanx 3 stays on overwatch, secure on OGBM Objective 2.
And Monolith 1 doubles towards OGBM Objective 1 as well?
End of turn: Necrons 1 (T-n-H) vs OGBM 0 (none)
PostPosted: Fri May 26, 2006 8:07 pm
Quote (Chroma @ 26 May 2006 (19:54))
So what happened to The Deciever? I saw Monolith 2 get destroyed... But The Deciever doesn't seem to have activated that turn at all  :8:
Turn 4
The Deceiver teleports near the Kustom Gargant, while Monolith 3 appears at the mid-line.
Strategy roll: OGBM
The Gargant doubles to fire on Eques 2, knocking down 1 Heavy Destroyer.
The Big Krawla sustains fire again, at Eques 2, and finally manages to destroy all the annoying skimmers.
The Deceiver charges the Kustom Gargant doing 2 DC damage and a critical, but the Star God suffers a debilitating hit and fades away? now who's laughing?!
The Kustom Gargant doubles towards Monolith 3, breaking it.
The Pylon sustains fire again on the Big Krawla, but misses.
Phalanx 1 marshals onto OGBM Objective 1, and restores 5 Necron Warriors.
Monolith 1 doubles to fire on the Big Krawla, to no effect.
Phalanx 2 goes on overwatch.
While Phalanx 3 remains on overwatch as well?
End of turn: Necrons 1 (T-n-H) vs OGBM 1 (BTS)
Tie-Breaker: Necrons 825 vs OGBM 1125
PostPosted: Fri May 26, 2006 8:10 pm
Quote (Ilushia @ 26 May 2006 (20:07))
So what happened to The Deciever? I saw Monolith 2 get destroyed... But The Deciever doesn't seem to have activated that turn at all ?:8:
Taken care of, must've some how missed that in my cut-n-paste.
PostPosted: Mon May 29, 2006 4:10 pm
it's harder for the phalanxes to fight War Engines.  :cool:
I would have loved to see what the Nightbringer would have done here.  :devil:
Necron Army Champion
PostPosted: Tue May 30, 2006 4:50 pm
Quote (corey3750 @ 29 May 2006 (16:10))
it's harder for the phalanxes to fight War Engines. ?:cool:
I would have loved to see what the Nightbringer would have done here. ?:devil:
I still think the first strike on The Deceiver is hard to resist taking...
If The Nightbringer had been around, I would've tried a lot harder to break Him... cuz in base with a Gargant, He'd be getting an incredible 11 + 1TK (d3) CC attacks!   :O
