[BatRep] Necrons vs Termagant Terror - 2700 points
 Post subject: [BatRep] Necrons vs Termagant Terror - 2700 points
PostPosted: Thu Mar 09, 2006 4:39 pm
Here's a report about the Necrons facing the Bug monstrosity know as The Termagant Terror!
I've got a couple questions/comments to make about Necrons that were generated by this fight and I'll post them soon.
PostPosted: Sat Mar 11, 2006 5:47 pm
Thanks for addressing the Gauss Flux Arc question in the Tyranid thread Corey!
My other question was about the Abattoir's critical hit effect. ?It seems odd that it gets a save (Living Metal) against its own critical and it almost seems potentially beneficial to the Abattoir if it happens while surrounded by enemy units.
Might I suggest the following change:
Critical Hit: Capacitor explosion. The Abattoir suffers an additional point of damage and inflicts a MW 4+ TK(1) attack on every unit within 5cm.
As well, the with the Aeonic Orb critical generating a BP 4 (MW) attack on a crit, does that mean *two* templates are placed?
Thanks! ?And we've had great fun playtesting the Necrons!
PostPosted: Sat Mar 11, 2006 6:45 pm
I wish I could get a single game in!
I truely envy you. :)
PostPosted: Sat Mar 11, 2006 7:18 pm
Quote (primarch @ 11 Mar. 2006 (17:45))
I'll trade ya some friends for some minis, Primarch!   :D
PostPosted: Sat Mar 11, 2006 7:49 pm
Quote (Chroma @ 11 Mar. 2006 (16:47))
Not a problem. It's specified in the 4.1 version, which I'm still tweaking.
Yes, it can be potentially beneficial to the Abattoir, but then, so can a lot of criticals.
The Chaos Titan crits for example.
And as to the Aeonic Orb, it places only a single template, centered on itself (I've made the changes to the new list to point that out).
I should point out that the last time I fielded a Harvester engine, the crits did more damage to them than the enemy.  (in fact my orb did 3 wounds to itself off a single hit  :80: )
And thank you for all the playtesting!  I need all the info I can get.
Necron Army Champion
PostPosted: Sat Mar 11, 2006 7:54 pm
Quote (corey3750 @ 11 Mar. 2006 (18:49))
I believe, in the latest version, the Chaos Titan criticals were redone to avoid precisely that, that, while a crit may hurt the enemies, it should, basically, always hurt the war engine suffering it.
PostPosted: Sun Mar 12, 2006 12:16 am
Quote (Chroma @ 11 Mar. 2006 (12:54))
@Chroma,
EXACTLY - crit should be bad. They are a reward for the enemy, not a boon to the controlling player!
Rob
PostPosted: Sun Mar 12, 2006 1:54 am
Imperial and Ork Titan crits are only POTENTIALLY bad.
In fact, on an Imperial Battle Titan, there's a 50% chance that nothing bad will happen to them at all.
For their scout titan, the crit is almost laughable.
Ork Titans have it a little worse, since they only have a 33% chance of having it do nothing, but then they don't have the 1 in 6 chance of it blowing up like an Imperial Battle titan does.
I just dont' understand this insistance that everyone seems to have that every race with BETTER technology should have more brutal crits.  Like the silly crit on the Eldar titans.
It's not really a bad idea to use crits to help balance out a unit (the crits on Engines of Vaul for example are a good balance).
You'll note, that the crit that happens to the Aeonic Orb is more severe than the Abattoir's.  That's because the Orb is, frankly, a more effective unit.  And because it's a stand off ranged unit, that crit is less likely to effect an enemy unit.
Now, what I have been considering is denying the Abattoir it's save, simply because it IS coming from inside, and reducing the effect on surrounding units to a normal hit.
PostPosted: Sun Mar 12, 2006 1:28 pm
Quote (corey3750 @ 12 Mar. 2006 (00:54))
Don't get me wrong, I *love* the brutality of the critical hit effect, I just don't like that the Abattoir is the thing least likely to be affected by it: it, and other Living Metal units, are the only things that can possibly get a normal save against it.
And, I believe, the reason the "hi-tech" crits are worse is that when something goes wrong in a hi-tech, hi-energy environment, it really goes wrong!  *laugh*
PostPosted: Sun Mar 12, 2006 3:39 pm
But on balance it never (or so nearly never as to be almost indistinguishable) is beneficial to the Imperial player.
