Portals and Post-Assault Moves
 Post subject: Portals and Post-Assault Moves
PostPosted: Tue Jan 24, 2006 2:36 pm
Ok, here's another one, er couple...
1. As part of the movement following an assault, can a Necron unit within 5 cm of a portal, consolidate into that portal and take themselves off of the table?
2. On the other side of the coin, can a Necron unit that has lost an assault use their Withdrawal move to jump back into a portal?
3. Finally, can a Necron unit that assaulted out of a portal, consolidate or withdraw back to the same portal they came out of?
Thanx!
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Tue Jan 24, 2006 6:39 pm
Hena,
Good catch. That would be nicer if we only had to get within 15 cm, but that seems like we'd be getting extra movement.
However, I'll let Corey comment.
Honda
PostPosted: Wed Jan 25, 2006 1:38 pm
Provided the portal had not been used before in the turn, then yes.
Again, provided that the portal had not been used before in the turn, yes.
And might I say that I'm very pleased that someone noticed it.  :)
No.  The Portal has been used, and cannot be used again until the next turn.
Necron Army Champion
PostPosted: Wed Jan 25, 2006 1:41 pm
That is a good question Hena.
However, the 15cm only applies for the Synchonized portals.  If you look earlier in the Portal Entry, it says that you have to enter the portal as part of your movement to go back into the reserves.
But I can also adjust things to make that more clear. :)
