Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
Armylists for the European Epic Championship 2014
 Post subject: Armylists for the European Epic Championship 2014
PostPosted: Wed Jun 04, 2014 10:20 am
Dear army champions.
instead of using the epic-uk lists, I decided to use the NetEA lists at the European Epic Championship 2014.
So I have to compile a list of army lists
Could you please pm or mail (brumbaerATbrumbaer.de) me, where I can download the current stable version of your army list(s).
Provided that you agree, I will put a copy on a website for reference and download.
I want to put the lists on a separate website, so that nobody can say, that he had a different version.
I will remove the files once the championship is over.
Thank you for support.
Regards
Stephan
 Post subject: Re: Armylists for the European Epic Championship 2014
PostPosted: Wed Jun 04, 2014 12:13 pm
Hi Brumbaer?
I'm a sublist champion here. What's the aim? Do you want only approved lists? Or develompental as well.
If I may suggest something then I'd say go for only approved lists for such a big event. If you do, then you can find the latest necron list in the tournament pack.
cheers.
PostPosted: Wed Jun 04, 2014 2:20 pm
Borka wrote:
Hi Brumbaer?
cheers.
Hi Borka,
basically I want the version, you would feel confident about to be put in the next tournament pack.
So it should be approved, if possible and should be at least developmental.
If even not developmental, I'd like to have the version, you think will be the future :)
Generally I plan to not allow experimental lists despite the groans that might earn me, but may make an exception for races that are only covered by experimental lists - or not.
PostPosted: Thu Jun 05, 2014 1:35 am
The list that will be appearing in the 2014 Tournament pack is identical to the 2013 list, with one small change: Pylons are no longer a Maniple choice (instead being purchased directly from the Harvesters 1/3rd section). I'll see if I can track down an actual downloadable version of it.
PostPosted: Thu Jun 05, 2014 10:31 am
Thanks for your help, it's really appreciated.
PostPosted: Tue Jun 10, 2014 12:18 pm
viewtopic.php?f=21&t=27573
