Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
Current List Adjustments
 Post subject: Current List Adjustments
PostPosted: Sun Jun 07, 2009 2:41 am
C'tan criticals: change to MW4+ in a 5cm radius.
Strategy Rating: Remove variable Strategy Rating rule, and replace with a fixed SR 2.
Deceiver: change the BP from BP 6 to BP 4.
Armored Phalanx:
Remove from Core formations, and returned to a support formation.  The basic Necron Warrior Phalanx is the only core formation.
Replace the Portals rule with the following:
Necron Portals are the primary means by which the Necron forces are transported across the galaxy.  Any formation that is in the reserves, either because it has not entered play or has left the board for any reason, may enter play via a portal as part of any activation that allos movement.  Measure their movement using the portal as the starting point.
Additionally, formations may leave the board by entering a portal, taking them into the reserves.  Note that once in the reserves they can either re-enter play immediately via another portal, provided they have movement, or remain in the reserves.
Thus a Formation may enter one portal with part of their movement, and exit from a second, unused portal, continuing their movement from that portal.
If, at the end of the movement, the unit is out of formation, any units not in formation are destroyed.  Thus if you moved a formation through one portal, and out another, and not all units were able to make the full movement, the units left behind would be destroyed.
Portals can only be used by Infantry/Lv or Armored Vehichles with the Walker ability may use the portals.  Each portal can be used only once per turn.
Necron Army Champion
PostPosted: Sun Jun 07, 2009 5:29 am
You need to retain the notes about each portal only being used once per turn and only infantry/LV/walker can use them.
PostPosted: Sun Jun 07, 2009 10:35 am
Additionally, formations may leave the board by entering a portal, taking them into the reserves.  Note that once in the reserves they can either leave at immediately, provided they have movement, or remain in the reserves.
Underlined section should be:
...they can either re-enter play immediately via another portal...
PostPosted: Mon Jun 08, 2009 4:29 am
I appreciate the editing assistance.  :blues:
Noted changes made
 Post subject: Re: Current List Adjustments
PostPosted: Fri Sep 17, 2010 8:11 pm
Locking this old thread.
