Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
Harvester Engines
 Post subject: Harvester Engines
PostPosted: Wed May 17, 2006 2:09 am
it is supposed to have a 20cm movement.
Necron Army Champion
PostPosted: Mon May 22, 2006 3:10 am
Okay, I thought so.  Thanks.
Maybe on the next revision the speed can be changed to avoid confusion.
PostPosted: Tue May 23, 2006 7:27 pm
Quote (Moscovian @ 22 May 2006 (03:10))
By the way, Corey, do you plan to issue a new version of the Necron list anytime soon ?
I think there are only a few minor things to adjust before the list can be considered "final" (well, as final as it can be without the "official" stamp), namely :
- Number of attacks on Monoliths (although I've never been able to abuse them, they are potentially abusive and should probably be limited);
- Harvester engines : I've already made a couple of suggestions on how I believe they could be improve, as have other players. I think that the Orb and Abattoir are, at the moments, the units that need the most changes (nothing drastic, though);
- Clarifying the Portal rules, which can be a bit confusing sometime.
And (I think) that's it!  :D
PostPosted: Wed May 24, 2006 1:43 pm
I've been making notes on the various battle reports and suggestions.
I'll try to flesh out the update over this weekend, since it will be a long one. :)
PostPosted: Wed May 24, 2006 2:26 pm
You da man! ?Looking forward to finally putting together my Necron Army. ?Thanks for all the work you've put into this, Corey.
PostPosted: Wed May 24, 2006 2:36 pm
Quote (corey3750 @ 24 May 2006 (13:43))
That's great news!  :D
Thanks for all the good work.  :)
PostPosted: Wed May 24, 2006 9:13 pm
I love the idea of Necrons in Epic. Especially the organization on this list is awesome and rather neat. The new units to fill in the 'gaps' feel right in line with the main ideas of the Necrons (Be fast, be scary, vanish without a trace). If I had the money, and time, I'd try to put together a Necron army.
PostPosted: Sun May 28, 2006 6:13 am
Thanks guys.
I couldn't do it without all you.  :D
