Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
Fall of Damnos
 Post subject: Re: Fall of Damnos
PostPosted: Thu Mar 24, 2011 7:15 pm
Gaussplaterator! The Gawessome gun!
PostPosted: Thu Mar 24, 2011 7:30 pm
We've already got Tau Pathfinders and Alaitoc Pathfinders, at least this new thing has a different prefix.
PostPosted: Thu Mar 24, 2011 10:43 pm
I've always liked the word Ombudsman. We should work that in somehow. Don't worry that it won't make sense.
Obituator sounds like a bad He-man villain. I think he teamed up with Perspirator.
PostPosted: Thu Mar 24, 2011 11:04 pm
Obliquinator?
Obesinator?
Obviousinator?
Obsoletinator?
Ken?
PostPosted: Fri Mar 25, 2011 12:06 am
Moscovian wrote:
Obliquinator?
Obesinator?
Obviousinator?
Obsoletinator?
Ken?
I vote Ken! ::)
PostPosted: Fri Mar 25, 2011 2:28 am
Cenotaph?
Ostracon?
PostPosted: Fri Mar 25, 2011 4:32 am
I like obsequinator "yes m'lud, indeed m'lud" You might have to have seen Blackadder to understand though..
PostPosted: Fri Mar 25, 2011 3:51 pm
obliterator pylon sounds fine. also thinks ignore cover works, sounds like some of the chaos weapons.
"Out of earthshaker range" almost sounds like unlimited range, though i think that is a bit much.
i guess this would be something to go in the (much talked about, but never worked on) tomb guard list (or whatever the name is)
PostPosted: Fri Mar 25, 2011 3:52 pm
Why all this fuss over the name?
The unit is described as a pylon-sized artillery type unit called a Gauss-Obliterator.
So, that's its name.
From the description, in Epic it'd be some sort of BP weapon, but not with any great special ability like Disrupt or Ignores Cover.
PostPosted: Fri Mar 25, 2011 8:09 pm
Aw, you're no fun anymore.
PostPosted: Fri Mar 25, 2011 10:47 pm
Ditto. And weapon name isn't the same as unit name (earthshaker-basilisk)
PostPosted: Mon Apr 04, 2011 4:44 pm
Here are some ideas I considered for a gaussplaterator. They would leverage existing parts of the zombie robot war machine, hopefully requiring a minimum of new parts.
The idea is to add some arcs and replace the central gun. The ZRWM is a direct fire weapon that rotates on a turntable, and then pivots along a central mount for direct fire action, action, action.
The new design uses the arcs and some focussing junk to lob a wad of something in a high ballistic path, with the initial trajectory set by the magnetic fields of the arcs. I presume the wad is a piece of zombie metal that has been started to decay via gaussiness, reaching critical explosiveness near the end of its trajectory.
The three arc concept would need a new type of leg to help with the balance. And, obviously, the new parts in the middle would be fully gubbined in the zombie robot fashion.
PostPosted: Mon Apr 04, 2011 4:49 pm
Hmmm, since it's a "Gauss" weapon I imagined it would look something like this guy's gun, only bigger:Image
You could probably keep the two arc things of a Pylon, and just have a new "gun" piece in the centre.
PostPosted: Mon Apr 04, 2011 4:56 pm
Actually, I think the designs are junk, I just had to get them out of my system.
PostPosted: Mon Apr 04, 2011 5:25 pm
E&C, how would that kind of weapon fire indirectly?
