Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
Portal Usage
 Post subject: Portal Usage
PostPosted: Fri May 29, 2009 5:19 pm
And you *HAVE* to have "Yakkity Sax" from Benny Hill playing in the background as you play it.   :agree:
PostPosted: Sat May 30, 2009 1:58 am
so is it safe to say that this could also be a change to the list? just count the formation's normal movement while going through the portal. i can understand your reasoning for having the "scoop up." but teleporting is arguably one of the more powerful abilities and it would be good if it was downgraded some. not to mention it would be a lot easier for if we had one rule rather then several different ones.
PostPosted: Sat May 30, 2009 5:19 pm
yes.
Unless this is straightened out, no reason to test anything else.
I will alter things on the origional post.
Necron Army Champion
