Berlin urban camo
 Post subject: Berlin urban camo
PostPosted: Tue Jul 10, 2007 11:39 pm
I finally decided to try out a Berlin urban camo scheme on a DRM hammerjack, and I've got the base colours on.  Before I go on with highlights and/or shading, I thought I'd post pics and gather opinions.
http://www.cheddarmongers.org/prod....pg.html
The photos came out a little bright.  The 'white' and red are GW's new foundation Astronomicon grey and Mechrite red, respectively, and look better IRL.  I think I'll shade those two. :D  The black will be highlighted with dark blue, as per the previous scheme.
There's something not quite right, IMO, but I'm not sure what it is - apart from looking like a lego model.  After taking another look at RL examples here, I think I might reduce the size of the blocks, make them more 'blocky' (in terms of shape and arrangement), introduce more red (I included a little to have red somewhere, but in hindsight it seems conspicuous by it's... brevity; and Jane's Tank Recognition Guide has pics of a forest-camo Polish tank with a similar red which looks good.  But I digress), and just plain plan it a little bit better.
I'm looking for hefty critiques here, so please don't hesitate to be harsh. :;):
PostPosted: Wed Jul 11, 2007 12:04 am
Hi Vermis,
I had a quick look, closed the window to check your other links & now it wont open again!
From what I did see, I think you are correct that it would benefit from having more blocks in a smaller size.
I was going to say its a shame the colours are flat, in comparison to the nice dpeth you achieved on your previous models, but I see you're planning on upgrading that element already.
Overall, I really like it. I was thinking of doing similar, but time constraints lead me to a far faster scheme without the rigid shapes ( my workbench thread on the DRM forums ). It would be cool if you could post, your pics over there, or post a link back to the discussion here so others can see the great work you've done on the DRM stuff :D
Paul "TuffSkull" T.
PostPosted: Wed Jul 11, 2007 12:31 am
I like this version
the best of the three you did. Not sure if its just the camera or what. The lack of the white squares seems to make the rest of the ?paint scheme blend together better
PostPosted: Wed Jul 11, 2007 12:56 am
Doesn't really work for me.  I think the scheme is probably quite effective, but it's main purpose is to break up the outline of the vehicle.....which is something I don't think you actually want to do for a miniature to look good on the table.
Fire bad, tree pretty - Buffy
PostPosted: Wed Jul 11, 2007 1:00 am
Tuffskull: Hmm... yeah. ?Sorry about that. ?The site can be a little temperamental. ?Ta for the rest!
Pixelgeek: Thanks. ?Too bad it's the old scheme! ?I'd've gone with it, but I'm kind of obsessed about trying the Berlin style. ?But suggestions about the white square are noted, and hopefully smaller blocks will help with that problem too.
I'll just have to see if whole squadrons of tanks with smaller blocks drive me mad, though I actually enjoyed painting up that test.
Zap: smaller blocks. :;):  But, I know what you mean.  Hopefully some shading might help prevent it disappearing too.
PostPosted: Wed Jul 11, 2007 1:52 am
Maybe use an off-white instead of a solid white?
PostPosted: Wed Jul 11, 2007 2:07 am
I really like it. Almost looks like Dazzle. Actually I was chatting with someone who was going to do a Warlord in Dazzle, I think it could really work.
My Photobucket
PostPosted: Wed Jul 11, 2007 4:05 am
THey all Look good. The red is too red in the pics, verses what it really looks like. As you said. The "problem" with 6mm is if you make the camo too small it is "lost".  So the block size works for me. But again, the red should be (and may be) more like a red or rust brown. And if I use white, I wash over it with a thin blank wash. And/or use an off white ... As PG mantioned.
PostPosted: Wed Jul 11, 2007 5:26 am
What L4 said, you need a red that more of a brick shade than screaming eyeball blood red.  I don't know how much camo painting you've done before this, but it can be a pain.  The problem is, the whole idea behind camo is to make something look flat and blend in which goes completely counter to everything we learn about painting minis.  Darklining or washing the panels and such will do a lot to bring the depth back out without removing the camo effect.  If you're interested I did an article on painting camo on Reaper's website a while back.  I've got lots of camo stuff in my photobucket gallery if you want to see how I paint it (not that it's the best or only way).
My Photobucket: http://s21.photobucket.com/albums/b285/Sergeant_Crunch/
My blog
PostPosted: Wed Jul 11, 2007 7:36 am
Well, I like them just as they are :)
Back from oblivion (again)?
PostPosted: Wed Jul 11, 2007 10:18 am
you made the purpose
it breaked vahicle frame
problem is that at this scale you usualy  want to make frame more wisible, becouse vehicle could become unrecognisable bloob
thats problem i struggle with my historicals
if i paint the correct camo
they hides well on table but looks uncool...
PostPosted: Wed Jul 11, 2007 11:43 am
hi Vermis.
I like this scheme:
cheers
bans
Riau!!!!! O_o!
http://elbansblog.blogspot.com/
PostPosted: Wed Jul 11, 2007 1:30 pm
Ta for the input, all. ?Though I'd like to say that the 'white' is off-white. ?It's astronomicon grey, which is somewhere between space wolves grey and fortress grey, but maybe a tad brighter. ?Though if you go to the cloned topic at the DRM forums, it's a moot point anyway.
Sergeant Crunch: I saw your article soon after it was posted. ?Very helpful, it was. :)
PostPosted: Wed Jul 11, 2007 2:48 pm
The red needs to be toned down a little, but otherwise I like them.
PostPosted: Wed Jul 11, 2007 3:22 pm
Glad it was useful. :)
You know, I got on my soapbox and absolutely forgot to say that it looks really good.  Good enough to steal for some of my CAV models! :devil:
My blog
Users browsing this forum: No registered users and 179 guests
