,  warhound mars style
 Post subject: ,  warhound mars style
PostPosted: Tue Mar 06, 2007 7:29 pm
hi, im trying to design a convertion for the new style mars pattern similar to this fellow , now im planning on the forgeworld head legs and guns. but i need the smoother style torso with the underslung weapons instead of them attached to the side of the hull like the Sg one and the OOP model, (i hate that look on the hound, hence this idea.)
so any ideas for a part to use for the torso thats easily available?
Legio Nova guard: Finished
legio Storm lords: built
legio warp runners: un built
skitari: built
Eldar: in boxes
Orks: built, gargants painted
Ultra marines: 5 companies
Thousand sones: 5 companies (unpainted)
PostPosted: Tue Mar 06, 2007 7:45 pm
I would suggest using the SG Warhound torso/carapace, but instead of mounting weapons directly on the side, mount some sort of bit there.  Then you can mount the weapons to the underside of that bit.  That should give you a look similar to that FW photo in your link.
Understand this: that skag and his floozy...they're gonna die
PostPosted: Wed Mar 07, 2007 1:55 pm
its an option, but from what iv sen the body is far too thin. i was thinking about useing space marine dreadnought shin guards from 40k, but im unsure if these would be too large. and the would definately require heavy modifaction.
skitari: built
Eldar: in boxes
PostPosted: Wed Mar 07, 2007 8:00 pm
I was going to say something from the Space Marines too... not sure exactly what though. ??? Having a look at Firestorm40ks chaos titan the chaos dreadnought legs he used look just about right form wise. However I don't own a FW warhound so I have no idea if they'll be too big.
Maybe weapon turret casings from 40k tanks might work? ot sure if there's anything round enought but maybe from the archive predators? (If they're even still available)
I don't know your green stuff skills but since the body is fairly simple and rounded you just might be able to sculpt something decent looking. Green Stuff might not be perfect though: There's another product which name eludes me right now but it is easier to smooth for larger surfaces.
PostPosted: Thu Mar 08, 2007 3:01 am
I own both versions of the F/W War/Hnd and that is your answer, IMO !  :)
Users browsing this forum: No registered users and 180 guests
