Get-painted-kwik schemes
 Post subject: Get-painted-kwik schemes
PostPosted: Mon Jan 22, 2007 8:17 pm
Who wants, to live, forever.....?  :O
This means I must work on my armies, as modelleres etc.
I'm an easily distracted painter, and one thing which works is a fast paint scheme. one I've tried is:
black undercoat
brick red drybrush
leather drybrush
sand drybrush
very small yellow details (e.g. eyes).
I'd like some other quick-paint schemes suitabe for getting whole armies done in hours, instead of years. Any suggestions? Lighter-coloured ones would be of great help!
Back from oblivion (again)?
PostPosted: Mon Jan 22, 2007 9:21 pm
for marines, undercoat white, then ink.... pick out bolters and missle launchers ect....
done...
i have half a chapter done that way so far... it actually looks pretty good...
Legio Nova guard: Finished
legio Storm lords: built
legio warp runners: un built
skitari: built
Eldar: in boxes
Orks: built, gargants painted
Ultra marines: 5 companies
Thousand sones: 5 companies (unpainted)
PostPosted: Mon Jan 22, 2007 9:26 pm
Sounds good - would any shade of ink work well, or do you use any particular one? FOr example, as regards washes, chestnut always seems to have worked better than anything else.
Thanks.  :D
PostPosted: Mon Jan 22, 2007 9:38 pm
Would dipping be appropriate?
PostPosted: Mon Jan 22, 2007 9:46 pm
(Otterman @ Jan. 22 2007,21:38)
Yep - in fact, my loads of thined chestnut wash are practically the same - I just use a wide brush instead of dipping.
Thanks Otter.  :D
PostPosted: Mon Jan 22, 2007 9:48 pm
For my Ultramarines, I basecoated Ultramarine Blue (oh how I miss the spray cans with different colors), blue wash, drybrush Ultramrine blue, then pick out details. I've done at least 50 stands that way and it was pretty quick. I think it actually took me longer to paint the bases Goblin Green than the Marines themselves.
PostPosted: Mon Jan 22, 2007 10:00 pm
that dipping sounds interesant....
maybe I can test one....mmmmhahahahaaaa :D
cheers
bans
Riau!!!!! O_o!
http://elbansblog.blogspot.com/
PostPosted: Mon Jan 22, 2007 10:19 pm
my marines are ultramarines, i just use the neat blue ink from GW, red works well too.... and yes... basing takes 5 times longer!
skitari: built
Eldar: in boxes
PostPosted: Mon Jan 22, 2007 10:23 pm
Ah right. Must try the blue ink method. And I agree on the basing - I try to get out of it by applying sand or flock, but applying the PVA glue takes some time too. Thanks guys.
:D  :D
PostPosted: Mon Jan 22, 2007 10:35 pm
one thing i was toying with for the next five companies iv got to do is to attach hem to a stick whist they are painted and attach them to bases painted and flocked separately.....
may work.... or may just be a pain in the a$$
skitari: built
Eldar: in boxes
PostPosted: Mon Jan 22, 2007 11:25 pm
Pick your colour, buy tin of black spray undercoat and tin of colour you want.  Undercoat black carefully and fully.  Let dry.  Then spray with colour of choice from 30-40cms away.  Let dry.  Paint guns gunmetal grey, paint edges of base green.  Let dry.  Flock.  Done.
Fire bad, tree pretty - Buffy
PostPosted: Tue Jan 23, 2007 3:33 am
Hmmm ... Base coating and washing ... dry brushing ... detailing ... work ... work ... work ... :)
PostPosted: Tue Jan 23, 2007 3:34 am
Hey, I just had a great idea for basing speed! Paint miniatures on stick (I do this anyway). Paint base in green/brown/black/whatever. Apply watered-down PVA glue to base. While still wet, attach infantry, dip in texture material and allow to dry.
The big time savers are that you can paint the base without trying to poke around infantry limbs and the infantry and flock are using a single application of glue to attach them.
PostPosted: Tue Jan 23, 2007 9:23 am
If I'm doing armies and not special displays, I don't bother doing any shading.
Space marines - Undercoat Blue. Bolters in black. Silver to shine them. Do some details on shoulder pad. Done
Base wise, I just paint it green. It's only recently I started bothering with basing.
PostPosted: Tue Jan 23, 2007 11:25 am
has anyone ever tryed the "stick" method? i know some people paint figures on the sprue, would this be simial in effect, but would you run the risk of breaking figs when you tryed to base them?
skitari: built
Eldar: in boxes
Users browsing this forum: Google [Bot] and 53 guests
