Plague Tower
 Post subject: Plague Tower
PostPosted: Sat Nov 25, 2006 1:57 pm
im making a plague tower in 40k scale and want to be close to accurate on the scale. can someone gimme the height in CM and MM of the epic plague tower please.
thanks
PostPosted: Sat Nov 25, 2006 2:32 pm
Base size 2,5 cm x 4,5 cm
Height: 6cm
PostPosted: Sat Nov 25, 2006 4:59 pm
so if im doing my math correctly, a 40k scale plague tower would be 26 centimeters high, give or take?
how off would i be using a screaming bell as a base?
PostPosted: Sat Nov 25, 2006 6:23 pm
Some way off.  I think a screaming bell's about 10cm or less.
Raid your nearest DIY or hobby shop for suitable bits of wood or styrene rod. :;):
PostPosted: Sun Nov 26, 2006 9:08 pm
I would start from the Warhammer Siege tower if it's still available.
PostPosted: Sun Nov 26, 2006 9:29 pm
YEah, that's probably work alright. Make it slightly bigger, add some serious guns and sculpt the daemon faces from an absolutely ridiculous ammount of green stuff (Alright most types of modelling putty should probably work
Users browsing this forum: No registered users and 192 guests
