Necron Terrain
 Post subject: Necron Terrain
PostPosted: Tue Oct 24, 2023 12:43 am
Some of my new Necron terrain. Some are just up graded a bit. I used to flock much of my terrain pieces. But I started to use Woodland Scenic's Liquid Pigment Earth Tones. A tan, a gray slate and earth brown. It's like a thick wash. Looks more like real terrain. Base painting the original models with spray - Black or Tan. The next day just blended the colors. Of course, I use Clear Flat spray to seal it. And the bases I had a buddy make, and I copied then using an Alumilite Resin kit found in craft stores. I'm going to use these for Necron Terrain or Objectives. My other buddy made some Epic scale Scarabs. I sanded the base off and then painted then glued on. Also has some Alumlite pieces with little skulls on them. Cut them off and use them for Necron heads ...
 Post subject: Re: Necron Terrain
PostPosted: Tue Oct 24, 2023 12:49 am
More Necrons ...
PostPosted: Tue Oct 24, 2023 12:54 am
Nercons are spreading ...
PostPosted: Tue Oct 24, 2023 8:30 am
good classic necron aesthetic there, and interesting on the bases, those do look more realistic than flock
PostPosted: Tue Oct 24, 2023 3:55 pm
Thank you ! I do like the Necron theme, etc. I will do more bases without flock. But I will still use flock in some cases.
Users browsing this forum: No registered users and 271 guests
