6mm conversion
 Post subject: 6mm conversion
PostPosted: Mon Sep 10, 2018 3:52 am
Ive currently lost my mind and have started converting a 6mm space marine into an adeptus custodian. At most I want 5 for a stand but Im having a hell of a time getting greenstuff to stick. Any suggestions at all?
 Post subject: Re: 6mm conversion
PostPosted: Mon Sep 10, 2018 9:43 am
Superglue and eldar guarding head on, and use some plastic ork boar riders, or orc axe men pony tails and glue them on.
Or if you want to sculp, try another sculpting clay maybe, also wet your tools or they stick to the greenstuff,
PostPosted: Mon Sep 10, 2018 6:48 pm
I have the same issue. Some times adding a small hole helps if u can.
Otherwise use more yellow than blue in your greenstuff and it will be sticker. If it breaks off after it dries, superglue it.
Sent from my SM-G903F using Tapatalk
PostPosted: Mon Sep 10, 2018 7:48 pm
If you can, drill out the head and put a small wire in its place so the putty has something to stick to. Also, lubricate your sculpting tools. Skin oil works, just be aware that your spouse will judge you.
The Guardian idea sounds like an easier approach though. These should get you most of the way there:
http://www.galactic-intrigue.com/epicol ... rarian.jpg
http://www.galactic-intrigue.com/epicol ... rdian3.jpg
PostPosted: Tue Sep 11, 2018 9:57 am
Ive got a dedicated pot of carmex lip balm to keep my tools lubed. Ive noteded water doest last long for 28mm let alone 6 mm. I used a needle and some tiny sculpting tools but the struggle is to keep the GS on the figure. even if my tools lubed (no sexual puns there) it still stays on the tool not the model. I'll upload pics later. Im on to the arms and weapon now. The body is done
PostPosted: Sat Sep 15, 2018 12:58 am
Try milliput, the white one is very good and is extra fine and used by a lot of sculpters,
Users browsing this forum: Google [Bot] and 129 guests
