Where to get 20mm x 20mm Infantry Bases?
 Post subject: Where to get 20mm x 20mm Infantry Bases?
PostPosted: Tue Jun 20, 2017 4:26 am
I feel like I've seen 3rd party versions of the old Epic 2nd ed square bases, does anyone know anything more and if they can recommend them?
 Post subject: Re: Where to get 20mm x 20mm Infantry Bases?
PostPosted: Tue Jun 20, 2017 10:09 am
Push Vanguard Miniatures to do some! :p
In the meantime, have you looked at Shapeways already?
PostPosted: Tue Jun 20, 2017 10:23 am
you could easily adapt this tutorial...
PostPosted: Tue Jun 20, 2017 11:59 am
I have not, till now.
Edit: Do you actually buy the physical prints? or are you buying the ... what you call it (CAD file?) or something to print it yourself?
PostPosted: Tue Jun 20, 2017 12:46 pm
On shapeways you buy the actual prints, not the CAD file.
PostPosted: Wed Jun 21, 2017 12:00 am
I buy mine here: http://www.sarissa-precision.com/
While I preferred to make them 25mm (more space for the actual figures and detailing the base), you could ask them to make them 20 x 20mm as well as specify the thickness.
I use them heavily (and by heavily I mean THOUSANDS of bases so far). Great service, good prices.
They are based in the Uk and I like in the US, so ordering from them from anywhere is easy.
PostPosted: Wed Jun 21, 2017 6:44 am
So they will custom make them for you there?
PostPosted: Sat Jul 08, 2017 9:11 am
You can select the thickness when you add to cart (1, 2 or 3mm)
Also choose whether you want straight or rounded edges which is a nice touch
PostPosted: Sat Jul 08, 2017 9:44 am
primarch wrote:
Hi!.
If anyone wants "thousands" of bases, they should speak to John and I about tooling a plastic bases mould. I expect we can do them cheaper than anyone else.
PostPosted: Sat Jul 08, 2017 9:59 am
I ... don't think I'll need more than a 100 or so at this point, but thanks :)
I've been wondering if there is an actual better design than the standard bases, where infantry mini's 'plug in' easier and don't pop out if you look at them the wrong way. I've bent one Marine already trying to slot him in (thankfully just a case of some glue on the kneecaps).
PostPosted: Sat Jul 08, 2017 6:53 pm
I use a dab of paint on the bottom. You can force it out if ever u need to without damage.
Sent from my SM-G903F using Tapatalk
PostPosted: Sat Jul 08, 2017 9:05 pm
The ones I had made with Sarissa don't "pop out". The figs fit quite nicely.
That said I made them 25 x 25mm not the original 20mm which I always felt waas too small and made for a tight fit for some of the larger infantry (terminators, Ogryns).
PostPosted: Sat Jul 08, 2017 9:06 pm
Evil and Chaos wrote:
primarch wrote:
Hi!.
NOW you tell me?!
Where were you 3 years ago when this all started, LOL! ;D
PostPosted: Sun Jul 09, 2017 10:41 am
primarch wrote:
Hi!.
NOW you tell me?!
Arguing with the rubbish tooling house to get them to cast non-rubbish versions of the infantry & vehicles sprue, probably. :)
The tool room I use now is, non-rubbish. :)
PostPosted: Mon Jul 10, 2017 12:33 am
Well I tried contacting Sarissa about it, but got not reply, so, I don't if theres a better channel than their little 'ask a question' through the website thing.
