FW Warhound (and other Titan measurements)
 Post subject: FW Warhound (and other Titan measurements)
PostPosted: Thu Sep 22, 2016 3:07 pm
Hey, could someone in possession of the old resin Epic Forge World Warhound tell me the exact height of the model from bottom of the feet to the top of the boxy carapace? I could use the info in a project of mine.
Thanks!
 Post subject: Re: FW Warhound measurements
PostPosted: Sat Sep 24, 2016 12:42 pm
I make it 42mm:
PostPosted: Sun Sep 25, 2016 2:22 pm
Great, thanks! In the end it was not so much more as I had tought, just 4mm. It looks bigger in the pictures, then again it is bulkier than any of the other ones with those boxy shoulders.
I ended up measuring the rest of them for future reference: (no bases included, thin base would be 1mm, thick 25mm base 4mm)
Old GW Warhound 33,5mm to top, 37,7mm with spikes
New GW Warhound 38,3mm
Old GW Reaver 46mm to top, 54,3mm with rocket launcher on top, depends on the weapon
New GW Warlord 65,7mm to lower shoulder top, 69,3mm to upper shouler top (not weapon top)
Imperator 81mm to platform top, 104mm to cupola top, 129mm total with towers
 Post subject: Re: FW Warhound (and other Titan measurements)
PostPosted: Thu Sep 29, 2016 1:37 pm
Here is a picture for scale reference for those that do not own all of them. In hindsight I probably should have but a white paper in the background to make it clearer.
Users browsing this forum: No registered users and 84 guests
