Alternative miniatures for IG Rough Riders ?
 Post subject: Alternative miniatures for IG Rough Riders ?
PostPosted: Fri Nov 27, 2015 12:47 pm
Hey there,
I am looking for alternatives to the regular Rough Riders. I know of these miniatures:
- GW very old sculpt, plastic
- GW E40K era, plastic
- E&Cs Not-Death Korps Riders
- Steelcrowns Not-Mukali Riders
These are fine models BUT: They all have coats. Which does not fit well with my Catachan Infantry. I COULD sculpt and cast them, no sweat. But I only need a handful of them, so costs would be not proportional to use. I need 6 Bases, thats it. So 18 Miniatures, which is, again to much to sculpt all (far too lazy).
So I am looking for alternatives. Alternatively: Horse Dollies in 6mm.
Any help would be appreciated.
 Post subject: Re: Alternative miniatures for IG Rough Riders ?
PostPosted: Fri Nov 27, 2015 1:30 pm
http://vanguardminiatures.co.uk/shop/no ... r-cavalry/
These have coats I know, but they are not too obvious?
PostPosted: Fri Nov 27, 2015 1:47 pm
Also the quad bikes from latest stuff from vanguard can pass as rough riders
http://vanguardminiatures.co.uk/shop/novan-desert-quadbikers/
thats what i plan for my future to do Tallarn force.....
Soul Reavers Chaos Warhost PLog
Tau Empire T´ros Coalition PLog
PostPosted: Fri Nov 27, 2015 3:47 pm
If you really want to go over the top > http://www.pfc-cinc.com/catalog/item/80 ... 644370.htm
PostPosted: Mon Nov 30, 2015 8:20 am
Honestly? Any 6mm historical cavalry. Baccus 6mm Boers would work well as would some of the Ancients just avoid any mounted archers and they'll work!
Rightyus Indergestyun I
Stabb-Blasta II
Verum Irae II
PostPosted: Mon Nov 30, 2015 1:43 pm
The Boers are nice, do you have a comparision pic by any chance? I only have the WSS range.
PostPosted: Mon Nov 30, 2015 2:24 pm
Even WWI German Cav ... would work in that case ... Check out Baccus > http://www.baccus6mm.com/catalogue/GreatWar/Germans/ Looks at this code # GWG15 - German Uhlans
PostPosted: Mon Nov 30, 2015 4:55 pm
I know Baccus, I have met the guy in person several times (at show, CRISIS for example). He is a nice chap and the minatures are well priced. I am most tempted by the Boers.
If I could mix em up with my Catachans, that would be ace. But Baccus tends to be on the more realistic 6mil track while GW is more at the upper, nearly 8mil/10mil. So these could not fit, thats why I was asking.
I have some WSS Cav (the old range) laying around, must have a look at them when I have the time.
Blank dollies could also work, or converting regular Riders...
PostPosted: Mon Nov 30, 2015 5:00 pm
I have a bunch of the plastic cadian style GW rough riders available if you go down the 'slice up and convert some' route ;)
