hooked brushes
 Post subject: hooked brushes
PostPosted: Wed Aug 12, 2015 7:26 am
I've got a nice R&Co 0/3 brush I use for detail work on epic minis, recently it started to hook, as the brush is a semi-synthetic blend, I followed some advice from a quick google search and dipped the very tip of the brush into a mug of boiling water for 3-4 seconds, a quick reshape later and the hook was gone! I've now got my lovely fine detail brush back
just thought I'd share, if your beloved brush hooks, don't chuck it away or relegate it to drybrushing or basing, try dipping the very tip in some boiling water to soften the fibres and reshaping it
you're welcome!
oh and if all the bristles fall out, you dipped it in too far.... don't blame me... ;)
AS IT MAY BE UNCLEAR ABOVE, DO NOT DIP THE WHOLE END OF THE BRUSH IN THE WATER, JUST THE 1-2MM THAT ARE HOOKED, MORE AND YOU RISK MELTING THE GLUE HOLDING THE BRISTLES IN
Last edited by kyussinchains on Wed Aug 12, 2015 12:53 pm, edited 2 times in total.
 Post subject: Re: hooked brushes
PostPosted: Wed Aug 12, 2015 7:33 am
Do you have a source on that? Sounds like a typical "synthetics-brush" problem to me, so I am interested as well.
PostPosted: Wed Aug 12, 2015 8:21 am
Same here thrown away a good few will try the hot water :{[]
Cheers for the tip ;)
PostPosted: Wed Aug 12, 2015 8:24 am
@Largo, I tried to dig up where I found it but can't remember the exact search term I used.... I make no promises! just thought it might rescue a brush here and there :)
just remember it's only the hooked bit that goes in the water, just the first 1-2mm, any more and you risk melting the glue holding the bristles into the ferrule!
PostPosted: Wed Aug 12, 2015 10:06 am
Glad you posted that about been the first 1-2mm or I would of dipped the lot ;D
Users browsing this forum: No registered users and 151 guests
