tutorial: making epic bases cheaply and in bulk
 Post subject: tutorial: making epic bases cheaply and in bulk
PostPosted: Thu Jul 02, 2015 8:12 pm
This tutorial covers how to make your own epic bases cheaply, quickly, and to a good level of finish. The bases shown here cost me under 1p each.
Orange bases from this tutorial, showing 4 and 5 hole variants next to a GW base.
I’m focusing here on 12*40mm bases (regular epic strip base size) with 4 holes, but the same method will work for bases of varying size and hole configuration. The skills and tools needed are minimal, if you can cut in a straight line with a ruler and own a drill you’re all set.
I find 4 hole bases useful as many of the GW epic figures look crowded at 5 to a base: ogryns, marine scouts, and khorne berserkers are all good examples. It also helps to economise when using rare models.
You need some 1mm styrene sheet (see below), poly cement (plastic glue), masking tape, a scalpel, steel rule, a 6mm drill bit and a drill.
Drills, knives and poly cement are all potentially dangerous, if you hurt yourself it’s your fault. I used a hand drill, if you want to bring in power tools that's your look out, take relevant safety precautions!
If you're doing a lot of bases, you need to obtain 1mm styrene in bulk. You could buy ‘hobby’ styrene sheet (woodland scenic etc), but that’s a really unnecessarily expensive way to buy a very cheap material. Instead, you can buy 1mm HIPS (high impact polystyrene sheet), normally intended for vacuum forming, cheaply online in bulk. It’s available in a wide range of colours, I’ve got it in black and white, but have used red/orange here as it was on discount – 80p for an A2 sheet!
Step 1 – blanks
Once you have your styrene, you need to mark out a grid of base blanks onto the sheet. I’m doing regular epic strip base size, so my blanks are 40*12mm. You need at least twice as many blanks as you want bases (two blanks per base, plus a few extra for spoilage).
How you mark the bases out on the sheet is up to you, but do it as a grid so you can just snap along the lines. I’ve attached a printable sheet to this post with 88 blanks drawn up on it, print full size (do not scale). I spray-glue this onto the styrene directly and use the lines as a guide. (more details on this and scoring/snapping the bases out added in post 13 of this thread)
88_12_by_40_base_blanks.pdf [8.44 KiB]
Downloaded 710 times
Do not cut the bases from the sheet, just score with a sharp knife using a steel rule as a guide, then snap the styrene. It will break cleanly along the score line with minimal bur. Scoring and snapping is faster, safer, and gives a far better finnish compared to brute force cutting. Might need a bit of practice to work out how hard you need to score to get a good snap and minimal bur.
You should end up with lots of small rectangular styrene blanks, like so:
Step 2 – drilling
Next you want to tightly bind a bit over half of these blanks into small stacks using tape (this half will be drilled, the other half will form the lower layer of the bases). The larger the stacks the faster the drilling stage is. However, if you use a large number of smaller stacks you can get more variations in hole placement over the hole batch.
Hold the stack securely (not with your fingers …) and drill the desired number of holes. A 6mm drill bit is exactly the right size. You might want to mark the hole placement in advance of drilling, but for 4 holes bases it’s not really needed.
Depending on how close your holes go to the edge, the bottom most blank on the stack will often be damaged beyond use as the drill will rip it on exiting the stack (YMMV depending on your drill bit, drill, and method of holding the stack).
Step 3 – glue
Once drilled, un-tape the stacks and discard any damaged pieces. You should now have a pile of plates with holes and a pile of blanks.
(blanks not pictured here, they look the same as they did in step 1!)
Stick ‘em together using poly cement. You need less glue than you think.
If you scored, snapped, and drilled everything neatly there should be minimal bur meaning clamping is not needed while the glue sets. If not, you'll want to clamp them tight while the glue sets.
Bases!
Bases with painted minis in:
Alternative to drilling in stacks (if you don't have a vice/bench clamp?): after scoring the base blank grid onto the styrene, but before snapping the blanks apart, clamp the whole sheet to a bit of junk chipboard and drill the holes base by base. This involves a lot more drilling, but means you can give every base a different hole configuration. Extra care is needed when snapping if the holes are near the edges. Again, only drill half of the blanks.
 Post subject: Re: tutorial: making epic bases cheaply and in bulk
PostPosted: Thu Jul 02, 2015 8:23 pm
I have seen a lot of amazing things on these forums, but this idea ranks right up there with the best of them.
Simple awesome! :)
PostPosted: Thu Jul 02, 2015 8:30 pm
Brilliant. Thanks for sharing.
PostPosted: Thu Jul 02, 2015 9:06 pm
VERY nice guide, thank you!
PostPosted: Thu Jul 02, 2015 9:09 pm
Nice one Apoc put them on the market. ;)
PostPosted: Sat Jul 04, 2015 3:06 am
I would buy these in bulk!
PostPosted: Sat Jul 04, 2015 3:55 am
Yep, I'd be keen to pay someone else to do this for me ;)
http://wanderingmonsters.blogspot.com.au
'You should check this bloke's blog out, it's the bomb!' - HM Queen Elizabeth II (really)
PostPosted: Sat Jul 04, 2015 6:51 am
Isnt that just missing the point of this tutorial though? You can easily knock out a few hundred bases in a couple of hours with basic tools for effectively zero cash and yet people would just rather buy them than put any effort in
PostPosted: Sat Jul 04, 2015 7:13 am
this is amazing, thanks for the tutorial
could use the same techniques for making crew served weapon bases and stuff........hmmm to the hobby room!
My VII Legion thread.......hopefully when you click it i actually have done something new.......
The VII involved in battle reports, probably fighting Atcho, Locknar or moridin
PostPosted: Sat Jul 04, 2015 7:19 am
Horses for courses. Depends how much you like making stuff I suppose, versus how much you value your free time.
TBH I will probably do this purely because 4 hole bases are not readily available, if they were I'd probably buy 'em.
Either way, very nice tutorial!
Edit: that was supposed to be a reply to kyussinchains.
PostPosted: Sat Jul 04, 2015 9:27 am
looking up current ebay HIPS prices i may have under estimated the cost in styrene, these might cost you nearer to 2p each to make :spin A pack of HIPS like this: http://www.ebay.co.uk/itm/High-Impact-P ... 8373&rt=nc should make you ?900? bases. Should be able to get it cheaper though, i've bought it from school/educational science and design tech retailers at a good price before.
Also worth mentioning that a single layer blank with no holes is an easy way to base microworld games fantasy minis. Once you get the hang of scoring and snapping plastic it's a far faster way to make 1mm flat bases than cutting thin ply wood.
Not planning to make these for sale at present, though if anyone else wants to go ahead. Really, you can make an army's worth (maybe not nids/latd …) in an hour with a couple of £ in materials and common home hand tools – point here is to show how quick and easy the process is to DIY ;)
PostPosted: Sat Jul 04, 2015 11:41 pm
Man! I wish I had thought of styrene when doing my own bases.
I think this is a great material to use. I had been using a mix of hard plastic(very difficult to cut cleanly) and magnetic sheeting. You could do 1 layer of magnetic sheeting and one layer of styrene so that you auto magnetise your whole army.
I also really like the idea of printing out a sheet which you layer over the styrene for cutting. I was measuring like a pleb.
The 6mm drill is a good idea, but I didn't have one, so I used a hole puncher, since a standard office one is usually 6mm too.
Here's my tutorial, so you can compare: https://www.youtube.com/watch?v=Me7Q0n2VWz4
Great tutorial, well done!
PostPosted: Mon Jul 06, 2015 4:39 pm
Small addition to the tutorial to expand on snapping the plasticard. Probably not relevant to many of you, but for anyone not used to working with styrene sheet it’s kind of essential. This addition takes place in Step 1, in the gap where a large sheet of plastic magically turns into many base size bits of plastic!
Spray glue the template onto the styrene. I’m only using a small section of the template as I don’t need many bases. Only use spray glue in a well ventilated area, follow safety instructions etc. Notice I’ve left a border around the bases on the template sheet – it’s far easier to snap the border off and get a good clean edge than it is to line a sticky sheet of paper up perfectly on an existing edge.
Now score along all the lines. I say score, you actually need to cut to slice through the paper, but you aren’t actively trying to ‘cut’ through the styrene. In the second picture you can see how light the score/cut line is.
Extend the edge base lines to the edge of your sheet so you can snap the template area off from the main sheet (using same method as below).
Now just snap along the lines, you should be left with a good clean edge and minimal bur. As you can see, the bits of paper template are already coming off, they can be removed any time after you score the sheet.
Now just keep going to break it all down into individual base blanks
If you don't have spray glue you can use a glue stick, but that's not very convenient for doing a whole sheet. A glue free alternative is to mark the edge points out through the template with a pin. Push firmly so a clear mark is made on the styrene at all the edge and corner points, then remove the template and just join the dots to daw the grid out.
PostPosted: Tue Jul 07, 2015 2:43 pm
If someone in the US was able to make these, I would gladly buy them! Easier for me to do that then make them
PostPosted: Tue Jul 07, 2015 3:48 pm
Simply love it !
