Salamander Green.....
 Post subject: Salamander Green.....
PostPosted: Fri Apr 17, 2015 7:05 pm
Hi there,
Painting up my Epic Blood Angels force in line with the colour schemes in WD142. Doing the assault company which specifies the company colour as 'Salamander Green'. Any thoughts on the appropriate colour from the current citadel range to mimic?
I know of the colour conversion chart but salamander green must of been phased out earlier than the last range as it's not on there. I have no idea if it's a dark green, bright green or whatever?!!! Anyone remember this colour?
Also on a completely different note anyone had problems using dettol to strip GWs latest range of spray paints? Missprayed some rhinos and 48 hours in dettol has done nothing to remove. Old batch of dettol so I'm hoping the fresh batch I've just applied will do the trick but was wondering if it's actually the paint... Dettols never failed me before....
Cred
 Post subject: Re: Salamander Green.....
PostPosted: Fri Apr 17, 2015 8:36 pm
Could just be the type of dettol if it's a new bottle, there is a less concentrated version on the market that is useless for stripping with. Or it could be the paint...
PostPosted: Fri Apr 17, 2015 9:22 pm
That's a color back from the late 80s, early 90s.
http://collector-info.com/Manufacturer/ ... assic.html
PostPosted: Fri Apr 17, 2015 10:31 pm
Thanks guys. So it's a dark dull green. Thanks I'm sure I can pick out a reasonably close match from the current range.
I'll advise on the dettol situation - it's definitely not the bottle I'm using unless the less concentrated version comes in exactly the same bottle as the original stuff.
Cred
PostPosted: Mon Apr 20, 2015 10:17 am
I just bought Bio Strip from Amazon which I've heard is great for everything - plastic, metal and resin. Will report on my findings after using it tonight.
D.
Users browsing this forum: No registered users and 174 guests
