Has anyone ever kitbashed a Khorne Lord of Battles?
 Post subject: Has anyone ever kitbashed a Khorne Lord of Battles?
PostPosted: Mon Mar 16, 2015 4:28 pm
I'm looking over the Chaos lists, and I was wondering how to represent the Lord of Battles.
I was thinking that in terms of a more "modern" 40k equivalent, that has been turned into the Lord of Skulls for 40k:
http://www.warseer.com/forums/attachmen ... 1390001520
I've seen fan suggestions to turn it into a "Lord of Scorpions":
http://3.bp.blogspot.com/-fBqKczxHyto/U ... 9185_n.png
I was thinking that some kind of super heavy tank from Defeat in Detail might form a good main body for a Lord of Battle, and maybe one of these over the top warrior torsoes:
http://www.games-workshop.com/en-EU/Kho ... Web-Bundle
Would be good to kitbash to the front of it. Not sure about a chaingun / chainfist arm combo though.
I was thinking maybe a Reaver titan could proxy for it, too, but it might be too large? The LoB is meant to be a smallish war engine about the size of a Warhound.
 Post subject: Re: Has anyone ever kitbashed a Khorne Lord of Battles?
PostPosted: Tue Mar 17, 2015 12:11 am
Hi! Good idea!
I don't remember exactly the range, but Warmachine has some mechs that fit fine as Khorne in my opinion. Another alternative could be to use a 40k berserker torso for the part.
Let us know if you make any conversion!
Gwydion
PostPosted: Tue Mar 17, 2015 3:36 pm
Using some 40K stuff you could make one ... I'd check on eBay for bitz ...
PostPosted: Tue Mar 17, 2015 4:16 pm
With a DC of 6, it isn't actually that small at all.
PostPosted: Tue Mar 17, 2015 4:25 pm
I found 2 or 3 on eBay ... http://www.ebay.com/sch/i.html?_odkw=Ep ... _sacat=220
PostPosted: Tue Mar 17, 2015 6:03 pm
really depends on the scale/size you want. Lord of skulls would be much smaller i think?
For a lord of battles size thing i think a forge world 40k cyclops remote demo vehicle with a chaos warrior torso stuck on top would be about the right size.
PostPosted: Wed Mar 18, 2015 8:38 pm
Ooh that's an interesting suggestion!
I'd need to buy a tonne of 40k scale bits, just skulls, endless skulls to put around the chassis. =D
I'm trying to figure out what the best chaingun / chainsword bits would be at that scale.
PostPosted: Wed Mar 18, 2015 11:32 pm
at that scale id think this for the chain weapon: http://www.bitsandkits.co.uk/images/457546873693.jpg
trim the end off one and the base off another and glue to two together for extra length if needed
chain gun on LoB is pretty big, so a generic 40k assault cannon should do. If not, maybe a WFP repeating pistol/blackpowder weapon from the empire range?
Skull – buy one, press mould the front off it.
for the dozer blade i wonder if the wheel covers or fairings from the new 40k ork bikers would work size wise
PostPosted: Thu Mar 19, 2015 4:04 pm
By the time you buy all the pieces, it may be cheaper to just get one on the eBay link I posted ... :eh
PostPosted: Thu Mar 19, 2015 4:28 pm
i don't think the victory condition here is price, L4.
PostPosted: Thu Mar 19, 2015 4:42 pm
Whilst I have a soft spot for the 90s era chaos Khorne war machines, I find them a little goofy and they'd be out of keeping with the more modern looking war machines.
I felt it would be great if I could make something that looked a bit more modern.
PostPosted: Sat Mar 21, 2015 10:03 am
This is a very good point, if it has the same DC as a Reaver Titan then I'm sure you can go for a much larger miniature which makes converting using 40k bits a lot easier.
I use a similar argument for my Ork Stompas...they're much larger than a Leman Russ (though they have the same durability) because I like to think Orks are less efficient with armour, engines, and weaponry leading to a much larger machine for a similar combat effectiveness. I'll tell you a secret though, I basically just wanted to use those miniatures in that role because they look awesome ;)
"I too shall be brought low by death, but until then let me win glory."
—Homer, Iliad, Book XVIII
The Unpronouncable Log!
PostPosted: Sat Mar 21, 2015 4:44 pm
I have 2 business degrees ... sorry ... I got to be me ... And it's rumored I'm 1/4 Ferengi ... I'm also a Retired PI ... Here's an old 40k Scale Chaos 'bot ... others have used for a LoBs ... And only $13.00 !!!!!! http://www.ebay.com/itm/Warhammer-40k-R ... 672wt_1157 :o All you'd have to do is cut off the C/Cbt weapons and mount Ranged weapons like found on the LoBs ...
animated-smileys-startrek-006.gif [ 165 Bytes | Viewed 6752 times ]
PostPosted: Sat Mar 21, 2015 8:57 pm
That's bleeping cheap for a Blood Slaughterer!
The Wargaming Trader
Users browsing this forum: No registered users and 168 guests
