What kind of glue do you use? I need help!
 Post subject: What kind of glue do you use? I need help!
PostPosted: Tue Mar 03, 2015 6:19 pm
I have about 2 thousand infantry to glue to bases. Super Glue is just too fumey for me. Anybody out there have luck with less fumey glue for infantry on stands?!? Mostly plastic on plastic.
Thanks
Pat
 Post subject: Re: What kind of glue do you use? I need help!
PostPosted: Tue Mar 03, 2015 6:28 pm
Fumy is relative (also I don't really know what level of noxious actual super glue is as a baseline to say if these are better worse or same).
However if any of this helps great=>
I tend to use several, the JetGlues (Slow, Standard, and Fast) depending on what I'm actually doing. For straight plastic to plastic, especially where thickness or other concerns about where it ends up getting on are important then I also use the old school testors liquid cement.
PostPosted: Tue Mar 03, 2015 6:51 pm
Plastic on plastic - you really should just be using bog standard plastic cement. I use the revell ones with applicator nozzles:
http://www.amazon.co.uk/Revell-39608-Co ... B000IYI0YQ
PostPosted: Tue Mar 03, 2015 7:50 pm
Good 'ole liquid poly is great for plastic-plastic, but that's also a bit whiffy.
If you really want to use superglue you can get odourless versions.
PostPosted: Tue Mar 03, 2015 10:46 pm
I just use a white glue for jewelry and such from the craftstore ...
PostPosted: Tue Mar 03, 2015 10:56 pm
Aren't the fumes the best part?
Only joking kids, don't try that at home!
PostPosted: Wed Mar 04, 2015 7:45 am
For plastic to plastic, I've had good results with non-toxic plastic cement. (Testors blue tube) It smells like oranges.
For metals to any kind of basing (MDF, balsa, metal, plastic), I've just used white glue. It's flexible but generally holds well. The good thing is that it's not permanent, and you can always rebase easily without destroying your miniature or paint job.
 Post subject: Re: Odp: What kind of glue do you use? I need help!
PostPosted: Wed Mar 04, 2015 10:21 am
If it is only for infantry try some pva glue (glue for wood) it is dirt cheap comes in large boxes and will hold without any problems. If you cover the entire base you can add some dirt on top to make some initial basing :-)
If You're from Poland and play Epic PM me maybe we can play a game :)
My wargame blog: http://6mmwargames.blogspot.com/
PostPosted: Wed Mar 04, 2015 11:23 am
What Azazel says with PVA.
Or if you want low smell plastic glue get the citrus stuff. I've switched to it, it's great!
http://www.tamiya.com/english/products/ ... /index.htm
Smells like an orange!
PostPosted: Wed Mar 04, 2015 11:25 am
Loctite Gel means it can be put where it's needed and doesn't run away.
D.
PostPosted: Wed Mar 04, 2015 11:31 am
Thanks everybody!
I'm definitely going to try the pva today. I've got some plastic cement (testors) coming, and I love oranges so I'll try that too!
Forgot that a lot of the bases are painted so I'm not too confident about the plastic cements but I'll give it a go.
As usual a wealth of information for the asking, thanks,
Pat
PostPosted: Wed Mar 04, 2015 1:39 pm
Just paint after glue :)
PostPosted: Wed Mar 04, 2015 2:59 pm
I paint Infantry separately ... then glue ...
PostPosted: Thu Mar 05, 2015 3:59 am
Does PVA for wood work well?
I like using white PVA (the kind schoolchildren use) because you can pull the infantry off of the base pretty easily, but sometimes it's too easy. I'd like something a little stronger, but not as strong as superglue (and definitely not as strong as plastic cement).
But when it comes to superglue, the kind with a brush applicator is much easier on the nose and lungs.
PostPosted: Thu Mar 05, 2015 6:47 am
@carlisimo109,
Thanks for the tip on the brush on. What brand and where do you get, please?
Pat
