Flyer Scale, Aeronatica Imperialis and other
 Post subject: Flyer Scale, Aeronatica Imperialis and other
PostPosted: Mon Jan 05, 2015 1:57 am
I’m in the process of making some of my own flyers for my Sisters of Battle army to be and I’d like to get as accurate a reading as possible to the scale of existing Epic scale flyers to get the new ones right. So what I’m missing is the length, width and height of the following:
Marauder Bomber FW (Aeronautica Imperialis)
Marauder Bomber GW new
Marauder Bomber GW old
Thunderbolt FW (Aeronautica Imperialis)
Lightning Air Superiority Fighter FW (Aeronautica Imperialis)
And any other FW Aeronautica Imperialis flyers you can think of, the chaos stuff I have. I’m going for fairly high accuracy as I’m using the measurements do define the right size for some never produced flyers like Arvus Lighter. So 0.00cm accuracy would be ideal. If you are feeling lazy but still helpful just the wingspan will do, as I have the “real” scale measurements for all but Avenger Strike Fighter from FW books.
Any and all measurements would be much appriciated.
 Post subject: Re: Flyer Scale, Aeronatica Imperialis and other
PostPosted: Mon Jan 05, 2015 9:22 am
Actually FW did do an epic arvus lighter and the aquila lander too i've have them stashed away for years.
PostPosted: Mon Jan 05, 2015 12:36 pm
Really? Pics or it didn't happen and measurements! Pretty pleace? :spin
PostPosted: Mon Jan 05, 2015 2:44 pm
I'll do that.
PostPosted: Tue Jan 06, 2015 8:47 pm
Arvus and Aquila from FW.
Arvus
hull length 31mm
wing span 30mm
cabin width 11mm
wing horizontal length 23mm
wing vertical width 7.5mm
Engine length 12mm
Aquila
hull length 40mm
hull width not including engines 10mm
hull vertical height 9mm
engine length 26mm
tail height 12.5mm
wing leading edge 30mm
wing trailing edge 37mm
wing horizontal width 27mm
overall wingspan approx. 90mm
PostPosted: Wed Jan 07, 2015 7:33 pm
Thanks for the measurements and the pics! I could have sworn they were never made for Aeronautica Imperialis, I guess I wasn’t paying enough attention to the imperial stuff at the time. I stand corrected sir. Any chance for the same treatment for Lightning or Marauder?
PostPosted: Wed Jan 07, 2015 7:41 pm
No problem sir glad to be of help if you need additional measurements on these please ask.
Yes sure not a problem if you can give me some time to do the measurements. They did the other marauder variants too, can't think of the names right now but you know the one with scanners and the one with the big bomb.
PostPosted: Wed Jan 07, 2015 8:21 pm
Colossus and Vigilant
PostPosted: Wed Jan 07, 2015 9:02 pm
Hey thanks jimmy that's the ones.
Users browsing this forum: No registered users and 127 guests
