osoi's Imperial Fists
 Post subject: osoi's Imperial Fists
PostPosted: Fri Nov 14, 2014 12:30 am
Well my first 3000pts is almost all assembled and I have started putting paint on some minis so I thought I should start showing them off.
These are the first 6mm minis that I have started to paint ever, so far so good
 Post subject: Re: osoi's Imperial Fists
PostPosted: Fri Nov 14, 2014 12:46 am
Nice!
PostPosted: Fri Nov 14, 2014 2:39 am
Mate.
Nice work, keep it coming.
Aaron
PostPosted: Fri Nov 14, 2014 3:18 am
Excellent! The 6mm Bug strikes again! :)
osoi, what do you use for basing and what are the colours used?
PostPosted: Fri Nov 14, 2014 8:25 am
Off to a great start! More imperial fists in the community can only be a good thing!!
PostPosted: Fri Nov 14, 2014 8:53 am
A great start indeed.
Can't wait to see them up close next week!
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Fri Nov 14, 2014 4:28 pm
Have to do something to counter the growing threat of Iron Warriors around here ;)
PostPosted: Fri Nov 14, 2014 4:31 pm
*looks shiftily at Onyx, Luca77 and Volrath*
.....quite.....
PostPosted: Fri Nov 14, 2014 4:52 pm
* cough *
viewtopic.php?f=7&t=24654&start=157
;D You're surrounded, mate
PostPosted: Fri Nov 14, 2014 5:13 pm
Nice!
PostPosted: Sat Nov 15, 2014 12:06 am
I work in metal fabrication so the bases are pieces of 2mm aluminium sheet that I cut to size or for the discs punched them out on one of our machines.
As for the actual basing material I have applied a coarse polyfilla to the base which gives some sculpting potential and has a finer texture than sand which is nice at this scale, then I have applied the GW brown texture paint over this in places to help it out a bit. The barbed wire is a spring from a lock cylinder.
So far the yellow is just a a couple of thin washes over an even white undercoat, I'll post a stage by stage coming up.
And yes there are a lot of Iron Warriors around, Onyx's are one of teh reasons for me choosing Imperial Fists so it should be nice to have a game with the two armies across from each other when mine is all painted
PostPosted: Sat Nov 15, 2014 3:21 am
I would like to see an artillery battle between the Ordinatus and the Titan in the IF list. :)
Users browsing this forum: No registered users and 163 guests
