Reaver Titan Weapon Question
 Post subject: Reaver Titan Weapon Question
PostPosted: Thu May 08, 2014 7:37 pm
Hi Guys,
Just curious if anyone knows. Are the metal Reaver Titan weapons and the metal Warlord Titan weapons sized the same? For example would putting the gatling blaster on the reaver look right or out of place? Just curious. Thanks!
Current EA Armies:
Steel Legion (6k+)
Orks (6k+)
Iron Warriors (Currently Building)
Daemons
My Commission Website: http://hulksmashstudios.webs.com
My Languishing Blog that will soon host some Epic stuff: http://hulksmash-homeplace.blogspot.com
 Post subject: Re: Reaver Titan Weapon Question
PostPosted: Thu May 08, 2014 7:41 pm
The E40k Warlord weapons have a different ascetic, and look a bit too big for a Reaver in my opinion. Obviously others might disagree.
I ended up making a GB for a Reaver using a metal 40k Terminator Assault Cannon and a VMB.
PostPosted: Thu May 08, 2014 7:46 pm
What's an VMB if you don't mind my asking?
Current EA Armies:
Steel Legion (6k+)
Orks (6k+)
Daemons
Vulcan Mega Bolter
http://wh40k.lexicanum.com/wiki/Vulcan_ ... 2vRWfldUxM
PostPosted: Thu May 08, 2014 7:52 pm
The plastic Warlord weapons are a better fit than metal ones.
PostPosted: Thu May 08, 2014 8:01 pm
I think the E40k warlord weapons are a perfect fit on the SG reaver, I have a gatling blaster on my nurgle reaver and a quake cannon on my artillery reaver, they fit and look just fine
PostPosted: Thu May 08, 2014 8:36 pm
Thanks for all the responses guys!
Current EA Armies:
Steel Legion (6k+)
Orks (6k+)
Daemons
PostPosted: Thu May 08, 2014 9:35 pm
You need to specify which warlord really. As there are metal warlord weapons for mk1, mk2 and mk3 warlords, all different sizes.
The metal gattling blaster from the mk3 is a bit bulky. The mk2/e40k metal gattling blaster fits ok for both SG and FW reavers, but ideally you'd trim the weapon arm down a bit as otherwise it sits a bit low compared to other reaver weapons (or make sure the other arm weapon is balanced with it). Mk2 weapons are generally a good fit (with arms adjusted where needed).
Users browsing this forum: No registered users and 211 guests
