My first attempt at painting Eldar |
sean_68333
Post subject: My first attempt at painting Eldar Posted: Thu Aug 29, 2013 4:52 am |
| Brood Brother |
Joined: Tue Aug 27, 2013 12:00 am Posts: 231 Location: Hickman, NE
I'm new to this game and am trying my hand at painting up an Eldar force. I thought I would post some pics and comments to see what you all think. I have done quite a bit of painting before, but mostly 28mm and 15mm. I have done some Dystopian Wars fleets as well, but there isn't any infantry so that doesn't really count as the same thing.
First of all, I don't like the GW bases as the models seem very crowded to me. So I decided to use 40mm x 20mm metal bases. These have the added benefit of being magnetic so storage and transportation will hopefully be a bit simpler as well. I will use 30mm x 30mm bases for jet bikes and I will use round bases for command bases so they stand out.
To start with, I clipped the models off the sprues and cleaned them up a little. I then glued them to balsa wood strips to make priming them easier. I primed all these models white. As a side note, I will be taping the strips down before I paint them next time. They are so light they kept being blown around by the spray paint.
I then used a wash to get the base coat on the models. I decided to use a wash as it flows better and it is very easy to get a coat on the whole model quickly. I'm not going for a museum finish. I want a decent paint job that can be done quickly. After that, I did a quick dry brush to bring out the details on the models. I didn't dry brush the Dire Avengers because I think they look okay with just the wash.
After the dry brush, I picked out a few details. The shuriken catapults were painted bone, the striking scorpions chain blades got a little silver and the dire avengers got red plumes. I painted all of this with the models still on the balsa strips.
Now with the models painted, I popped them off the balsa strips and started super gluing them to the metal bases. I have decided to put 4 models per base for the elder. I'm not sure if I will change this number for other forces, but it seems to work for these guys.
After they dried, I put down a coat of super glue on the rest of the base and added some ballast. My next step will be to paint the base brown and then add various flocks and lichen to break things up and give the army a unified feel.
Let me know what you think and if you have any pointers that might help me along on my trip to a finished army.
| Attachments: |
File comment: Dire Avengers with unfinished bases. I really like the look of these models.
File comment: Swooping Hawks with unfinished bases. I haven't decided if their weapons should be silver or bone.
File comment: Striking Scorpions with unfinished bases
File comment: a green wash is added to these rangers as their base color.
File comment: minis glued to balsa strips and primed white
_________________ The best player isn't always the winning player.
| Top |
kyussinchains
Post subject: Re: My first attempt at painting Eldar Posted: Thu Aug 29, 2013 8:34 am |
| Hybrid |
Joined: Tue Apr 19, 2011 12:03 pm Posts: 6355 Location: Leicester UK
looks like a quick and effective way to get models on the table!
personally I like to paint my infantry with quite a lot of detail, but the disadvantage there is how long it takes, 3 companies of imperial guard made me want to kill myself.... I've also got large ork and krieg armies which need painting and I am dreading so I think you're on to something here!
I'd suggest going for a contrasting base colour, the white works quite well and snow is a popular base style for eldar, but after doing my guard with brown muddy bases and them just merging into a generic brown mush on the tabletop, I'd make sure you keep the infantry and base colours very different, I've gone for a grey base for my imperial fists and they just pop right out...
_________________ Just some guy My hobby/painting threads Army Forge List Co-ordinator
| Top |
moredakka
Post subject: Re: My first attempt at painting Eldar Posted: Thu Aug 29, 2013 6:23 pm |
| Brood Brother |
Joined: Mon Sep 19, 2011 3:04 pm Posts: 6094 Location: UK
Hey welcome to the board, nice start on your eldar and the wash method seems to work well.
_________________ Vanguard Miniatures Link, http://vanguardminiatures.co.uk/Stockist of: Vanguard Miniatures BattleGroup Helios Onslaught Miniatures Pyrkol Gaming Markers Gregster's Lab Microworld Games Troublemaker Games
| Top |
sean_68333
Post subject: Re: My first attempt at painting Eldar Posted: Thu Aug 29, 2013 6:35 pm |
| Brood Brother |
Good point about making the base contrast the models. I haven't decided on what craftworld my elder will be from, but I'm leaning toward Sam Hain. Eldar tend to be so brightly colored there won't be any problems with contrast. I will be sure to keep that in mind when I start on a different army.
| Top |
jimmyzimms
Post subject: Re: My first attempt at painting Eldar Posted: Thu Aug 29, 2013 8:47 pm |
| Brood Brother |
Joined: Sat Feb 11, 2012 8:24 pm Posts: 9684 Location: Manalapan, FL
Good start and I'm looking to see more from you soon! I'll echo Kuss' point about adding a bit more. If you were to paint those Dire Avenger knee pads a light grey and then edge it with straight white they'd look ace and it wouldn't be a time murderer.
_________________ He's a lawyer and a super-villian. That's like having a shark with a bazooka! - I HAVE NO POINT- Penal Legion-Fan list- Help me make Whitescars not suck!
| Top |
sean_68333
Post subject: Re: My first attempt at painting Eldar Posted: Wed Sep 04, 2013 2:46 am |
| Brood Brother |
I'm going to get started on some guardians. I haven't decided on a craftword theme. Mostly I want one that I can paint quickly. Do any of you have any thoughts? If I do Bel-tan I can just wash the model green and then paint the helmet white. How do you all think that will work?
| Top |
kyussinchains
Post subject: Re: My first attempt at painting Eldar Posted: Wed Sep 04, 2013 4:13 pm |
| Hybrid |
it will probably work very well, are you washing it green over a white undercoat?
| Top |
sean_68333
Post subject: Re: My first attempt at painting Eldar Posted: Wed Sep 04, 2013 5:24 pm |
| Brood Brother |
Yes. I will prime the models white then wash with a green. I will paint the helmet white and the gun bone. Simple but effective. I'm gonna do a test to see how it looks. I hope to post a pic before the weekend is over.
| Top |
sean_68333
Post subject: Re: My first attempt at painting Eldar Posted: Sat Sep 07, 2013 3:22 am |
| Brood Brother |
Here are a couple of stands with finished bases. I like the mix of flock on these.
I'm wondering if I should add more flock to the bases? By that, I mean leave only a small amount of the brown "rock" showing.
What are your thoughts?
| Attachments: |
File comment: Swooping Hawks with finished bases
File comment: Dire Avengers with finished bases
| Top |
kyussinchains
Post subject: Re: My first attempt at painting Eldar Posted: Sat Sep 07, 2013 8:57 am |
| Hybrid |
I wouldn't add any more flock, looks about right as it is
| Top |
jimmyzimms
Post subject: Re: My first attempt at painting Eldar Posted: Sat Sep 07, 2013 5:19 pm |
| Brood Brother |
Yeah run a quick bit of dry brushing over the rock in a light brown and you're set. If you do each formation at a time for each stage you will find it is a great time saver. Keep up the great work!
| Top |
sean_68333
Post subject: Re: My first attempt at painting Eldar Posted: Sat Sep 07, 2013 7:07 pm |
| Brood Brother |
I actually did do a dry brush. I might have to use a much lighter color for it to be more noticeable. I'm not sure about a wash though. Maybe I will try it on a base to see how it looks.
| Top |
sean_68333
Post subject: Re: My first attempt at painting Eldar Posted: Tue Sep 10, 2013 4:14 am |
| Brood Brother |
Here is a pic of a stand of Striking Scorpions with the base dry brushed. I used bleached bone for the dry brush. The dry brush does make the model look better.
| Attachments: |
File comment: Striking Scorpions with drybrushed bases
| Top |
sean_68333
Post subject: Re: My first attempt at painting Eldar Posted: Tue Sep 10, 2013 4:20 am |
| Brood Brother |
Here is a couple of bases of guardians and a command stand with a warlock and guardians. These still need to be based, but I do like the look of the guardians. My next step will be to try this method on some jet bikes and weapon platforms.
I chose to do the command units on round bases because I'm not sure I will be using these for just Epic. I might also use these models for Future War Commander.
What do you all think of these?
| Attachments: |
File comment: Guardians
File comment: Warlock Command bases
| Top |
