Ordinatus Minoris- suitable weapons?
 Post subject: Ordinatus Minoris- suitable weapons?
PostPosted: Mon Jun 10, 2013 3:02 am
G'day guys,
I've picked up a handful of Morrigu Fire Support Vehicles to use as Ordinatus Minoris and while they're en route I'm trying to find suitable titan grade weaponry to magnetise for them. I've been looking mainly at Exodus Wars because of their great bits range. Issue I'm having is that I'm unsure whether the scale of the weapons will be right... The heavy tank range should fit size wise, the standard tank range has more of the weapons I'd like to see and then the Behemoth weapons are all arm hard points. I'm not sure how they'll look tacked on top of the Morrigu.
Suggestions, either on size or on alternative sources for weapons?
Guild Cerberus MRL Turret - Apocalypse Missile Launcher
Guild Exterminator Heavy Tank Turret - Vulcan Mega Bolter
Large Behemoth Triple Exterminator Cannon - Gatling Blaster
Large Behemoth Large Railgun - Volcano Cannon or Plasma Destructor
Images shamelessly stolen from the interwebs, not my work.
http://wanderingmonsters.blogspot.com.au
'You should check this bloke's blog out, it's the bomb!' - HM Queen Elizabeth II (really)
 Post subject: Re: Ordinatus Minoris- suitable weapons?
PostPosted: Mon Jun 10, 2013 5:44 am
I'm pretty sure the large behemoth weapons will be perfectly suitable, but I don't think the Cerberus is going to be large enough comparatively.
-Vaaish
PostPosted: Sat Jun 15, 2013 4:59 pm
Hi Short Bearded One,
I just quickly snapped these, hope they're of some use. I'd say anything of a size comparable with a warlord titan's weaponry and up should be fine.
Image#
The gun I used is from the original 40k necron destroyer
Or actually thinking about it you could probably pretty easily knock something up ion google sketchup and have it printed through shapeways. The morrigu seems to be a fairly popular minoris choice so there might be a small market for suitable options. And the mounting point is just a large blank rectangular surface with a hole in the center so pretty easy to work with.
You see a mousetrap, I see free cheese and a f*cking challenge
