Assembly Instructions
 Post subject: Assembly Instructions
PostPosted: Thu May 25, 2006 3:19 am
So.. I recently purchased a metal Warlord off of Chaosorc's website... And it occurs to me: I have no idea how you put these things together! The older ones are easy to figure out. But GW doesn't seem to list the individual pieces any more either so I have no idea how to put it together!  :down:
Any one have instructions for which piece is which and how they're supposed to fit together?
PostPosted: Thu May 25, 2006 9:22 am
I'm sure I saw a pic somewhere about but now I can't find it, I don't think I've an old box back to scan but somebody here definitly will.
PostPosted: Thu May 25, 2006 10:50 am
Is this the Mk2 or mk3 Warlord?
I find it easier to start with the basic parts: Feet, legs, head etc. Once you've isolated exactly which parts is causing the problem you can usually find out where they fit by examining a few pics of the finished model.
PostPosted: Thu May 25, 2006 11:39 am
Quote (Warmaster Nice @ 25 May 2006 (10:50))
I tried building from feel with my Tau battlesuits for 40K.  Each and every time I got the feet on the wrong legs  :p
Tyranid air marshal
PostPosted: Thu May 25, 2006 11:55 am
there is a wrong way for the Tau feet... *gulp*
If I remember correctly, the titans are pretty much
Feet, legs, body (you can tell this as the head slots into it), then the top shell that should sit nicely onto the body.
PostPosted: Thu May 25, 2006 5:53 pm
Do not bother trying to put it together. Just send it to me and I will get rid of the problem for you. :p
Serious, depends what mini version you are bilding, but I have found that if I start with the legs/"hips" and go upward it seems to work better. Just my .02
dafrca
              - Cities of Death, page 59
PostPosted: Thu May 25, 2006 6:48 pm
Does it look like this?  This is an old photo of my warlord when it was partially assembled.
This is the MkIII Warlord.
-Audrey
My Oubliette: http://audreysoubliette.wordpress.com
Old archive: http://oubliette.tranquility-base.us/
PostPosted: Thu May 25, 2006 6:56 pm
Probably should have been more specific: It's a Mk III Warlord. I can figure out MOST of it except how to set the hip-piece to the main body. Though I may be able to get that done with the pic supplied. Thanks Wraeth
