Converting Rhino's into Predators (and other variants)?
 Post subject: Converting Rhino's into Predators (and other variants)?
PostPosted: Fri Apr 19, 2013 8:23 am
Hi all,
I have wondered about the best, and cheap, way to do this.
I don't want to purchase GW Pred's as they're expensive and on eBay its usually the old SM1/2 Pred's that are for sale.
This 'may' be for a Chaos army so I'm not fussed it they look a little different, only want to ensure that they're at least recognisable as a Pred.
I could use the old Ork Battlewagon turret as those are a dime a dozen but i wanted something a little more 'Space Muhreeney'...
My thought was to use a standard plastic Rhino (from SM2 and E40k era) and possibly add the following:
Main Turret:
Exodus Wars Guild Achilles MBT turret
*Colour http://www.exoduswars.com/6mm-Guild-Achilles-MBT-Troop/dp/B006LM3AOO
*How large are these turrets - would they look oversized on a Rhino chassis?
OR
Exodus Wars Guild Hector AT IFV turret
*Colour http://www.exoduswars.com/Guild-Hector-AT-IFV-Detachment/dp/B006LM3KU8?field_availability=-1&field_browse=1479862031&field_product_site_launch_date_utc=-1y&id=Guild+Hector+AT+IFV+Detachment&ie=UTF8&refinementHistory=subjectbin%2Cprice%2Csize_name&searchNodeID=1479862031&searchPage=7&searchRank=salesrank&searchSize=12
*Note, the URL's really need to be shortened on this site.
*I like this turret a little better. It has broadly similar shape/style to the current Pred and it's offset cannon looks ok. Is this too small a turret, i.e. would it look like vehicle autocannon?
Sponsons:
Exodus Wars Twin Light Laser Emitter sponson
*On a Enforcer tank, it's the twin barrelled one http://www.exoduswars.com/Guild-Enforcer-Urban-Pacification-Squadron/dp/B006LM3IX2?field_availability=-1&field_browse=1479862031&field_product_site_launch_date_utc=-1y&id=Guild+Enforcer+Urban+Pacification+Squadron&ie=UTF8&refinementHistory=subjectbin%2Cprice%2Csize_name&searchNodeID=1479862031&searchPage=1&searchRank=salesrank&searchSize=12
*By itself http://www.exoduswars.com/Guild-Enforcer-Urban-Pacification-Sponsons/dp/B006LM4T3K?field_availability=-1&field_browse=1479862031&field_price=&field_product_site_launch_date_utc=-1y&field_size_name=Component&id=Guild+Enforcer+Urban+Pacification+Sponsons&ie=UTF8&refinementHistory=size_name%2Csubjectbin%2Cprice&searchBinNameList=price%2Csize_name&searchNodeID=1479862031&searchPage=1&searchRank=salesrank&searchSize=12
*The 'heavy bolter' sponson isnt twin barrelled but on its side and attached to a Rhino i think it would 'look' the part.
OR
Exodus Wars Grenade Launcher sponson
*On an Enforcer tank, it's the single barrelled sponson at the front of the tank
*http://www.exoduswars.com/Guild-Enforcer-Urban-Pacification-Squadron/dp/B006LM3IX2?field_availability=-1&field_browse=1479862031&field_product_site_launch_date_utc=-1y&id=Guild+Enforcer+Urban+Pacification+Squadron&ie=UTF8&refinementHistory=subjectbin%2Cprice%2Csize_name&searchNodeID=1479862031&searchPage=1&searchRank=salesrank&searchSize=12
*By itself here http://www.exoduswars.com/Enforcer-Pacification-Grenade-Launcher-Sponsons/dp/B006LM5VYG?field_availability=-1&field_browse=1479862031&field_price=&field_product_site_launch_date_utc=-1y&field_size_name=Component&id=Enforcer+Pacification+Grenade+Launcher+Sponsons&ie=UTF8&refinementHistory=size_name%2Csubjectbin%2Cprice&searchBinNameList=price%2Csize_name&searchNodeID=1479862031&searchPage=2&searchRank=salesrank&searchSize=12
* This one, on its side, could pass as a 'heavy bolter' sponson but I'm worried it might be a little small.
Essentially, has anyone done this before or is there a pic that clearly shows these sponsons on tanks next to a Rhino?
Tee
 Post subject: Re: Converting Rhino's into Predators (and other variants)?
PostPosted: Fri Apr 19, 2013 8:49 am
The battlewagon turrets might not be very marine-ish top turrets, but should work for sponsons. On a low budget the turret from the old plastic ork gun wagons can work for a very blocky destructor turrets, with E40k plastic land raider sponsons for annihilator turrets.
The basic shape is also very easy to make from 2 small piece of plastic card, cut to shape, cut opposing bevels on each then glue together. Slice a hatch from a rhino for the turret hatch, add some sort of rod or tube for gun barrels. Like this but with proper shaped turrets:Image
PostPosted: Sat Apr 20, 2013 4:29 am
Very clever Apoc - I think I may have to use the blocky Bonebreaka turret - though I was hoping for a more modern look. Although it does mirror the old 2nd/3rd edition rivet bound Destructor turret.
Does anyone have a pic of the above Exodus Wars models with a Rhino next to them?
Tee
PostPosted: Sat Apr 20, 2013 5:21 am
I've previously used the following to make Annhilators:
1xPlastic Rhino
1xMk2 Plastic Lanraider Sponson as a turret
2xMk1 Plastic Landraider Sponsons as...sponsons!
MoK's Painting Blog
Now Showing:
PostPosted: Sat Apr 20, 2013 5:28 am
Here!
viewtopic.php?f=7&t=13937&start=120
MoK's Painting Blog
Now Showing:
PostPosted: Sat Apr 20, 2013 6:12 am
I used the old plastic rhinos as the base for my Chaos Predators.
I used the old plastic Ork battlewagon turrets as the side sponsons (with a little trimming to the top hatch) and GHQ KV1 tank turrets (with some modifications).
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Sat Apr 20, 2013 4:16 pm
That works !
PostPosted: Sat Apr 27, 2013 9:25 am
Whirlwinds might be a useful basis as well as they've got the turret ring ready. For turrets I'd look at Aoshima's 1-700 Light Ordnane set. It's got plenty of machine guns and 12 turrets in the box for £7.50.
Rightyus Indergestyun I
Stabb-Blasta II
Verum Irae II
Users browsing this forum: No registered users and 148 guests
