Water effects
 Post subject: Water effects
PostPosted: Sun Jan 27, 2013 7:15 pm
What do you use? I am looking to fill a very small open tank with 5 mm transparent stuff. Seems to be a lot of opinions on various forums on which variant to get. Also, living in a small orner of he world, not everything seems readily available in Sweden.
 Post subject: Re: Water effects
PostPosted: Sun Jan 27, 2013 10:22 pm
I've only used Woodland Scenics Realistic Water on very small things so far but have seen it used very effectively in larger areas. I'd try that if you can get it (just add it in several layers of about 2mm and DON'T shake the bottle).
PostPosted: Sun Jan 27, 2013 10:24 pm
For my edification: WHY?
PostPosted: Sun Jan 27, 2013 11:03 pm
Have tried some resin casting and it was not a pleasant experience so comfort is important I suppose.
PostPosted: Sun Jan 27, 2013 11:47 pm
You don't need to as it doesn't seperate, like paints, and doing so creates air bubbles which you don't want (as elsmore said). I habitually shake stuff before using it so have to stop myself.
I'd wait and see what elsmore says about the Vallejo water effect. I've never been disappointed by their products and 35ml sounds like a better size for what you want. The Woodland Scenics Realistic Water comes in a large bottle and is really meant for rivers, lakes etc.
PostPosted: Tue Jan 29, 2013 4:12 pm
Vallejo Still water is excellent.
Are you in the UK Nitpick ?
http://angelbarracks.co.uk/
PostPosted: Tue Jan 29, 2013 10:18 pm
Occasionally. But I live in Sweden, as per the initial post.
PostPosted: Tue Jan 29, 2013 10:54 pm
D'oh.
My bad.
I can sell you some Vallejo Still water for free, if you will pay postage?
PostPosted: Wed Jan 30, 2013 12:05 am
Sure! Thats very nice of you. If you don't need it?
PostPosted: Wed Jan 30, 2013 9:05 am
No problmeo.
Can you drop me an e-mail please:
mail@angelbarracks.co.uk
PostPosted: Sat Feb 09, 2013 2:58 pm
Got a bottle of Vallejo still from the honorable gentleman Barracks the other day. Incredibly greatful for your assistance! Have since proceeded to pour said liquid into a smallish tank on a vehicle to represent Nurgle goo. The stuff does creep hugging features and edged quite a bit and there is a baffling amount of shrinkage the order of magnitude of a Swedish winter bath experience.
Having said this, it is my first attempt and I cannot say that a two part resin is better. It should shrink less though. Also, while the volume of the tank is small it is rather deep, 4-5 mm, that could probably be troublesome regardless of liquid. I have done 3 pours an I think that I will need another 1 or 2.
PostPosted: Sat Feb 09, 2013 4:19 pm
I found the same. I slightly over-poured the first layer (4-5mm) which then shrunk back alarmingly. I then had to just add layer after layer until I was happy with it, probably 5-6 more. It looks great now but you have to be patient... and not pick up the piece shortly after pouring a layer to check the paint job on the back of another section, pouring the liquid into your lap. Avoid that if you can, it's very messy.
PostPosted: Sat Feb 09, 2013 5:26 pm
:-[ now he tells me! Managed to avoid clothes though. The most annoying bit is the clinging. Luckily I'm doing Nurgle goo, so that fits fairly well. Does not look like water though. I'll get back when im done.
Users browsing this forum: No registered users and 71 guests
