Glue
 Post subject: Glue
PostPosted: Fri Oct 26, 2012 8:42 pm
Not a 6mm question as such but i want to use some "airfix" type plastic soldiers (you know the type-sort of greasy plastic) as armatures for some conversions , now i have some of the correct sort of paint for an undercoat spray but i remember having trouble with gluing on shields etc in the past.
What glue should i use?
 Post subject: Re: Glue
PostPosted: Sat Oct 27, 2012 12:56 pm
Varies a bit as not all of the plastics are the same. Some of the more recent kits by Hat use a different plastic and will will stick properly with styrene cement ('airfix glue'), otherwise have to try superglue and hope for luck.
Check out section 5 here re: gluing and converting polyethylene figures http://www.hat.com/Tips.html
edit: if you mean greasy plastic then probably polyethylene. There is also a softer plastic sometimes used that takes glue better (which Hat have used for some kits), and then very occasionally the hard plastic as used by GW, AFV kits etc.
PostPosted: Sat Oct 27, 2012 2:59 pm
Yeah, I'd go with Super Glue types ...
Users browsing this forum: No registered users and 157 guests
