Cleaning Old Paint
 Post subject: Cleaning Old Paint
PostPosted: Wed Jan 04, 2006 9:28 pm
What is the best way to clean old GW paint jobs off plastic and white metal minis?
Thanks
CAL
PostPosted: Wed Jan 04, 2006 10:00 pm
Brake fluid is great for stripping paint off plastics without damaging the model.
Simply drop the models in a bath of brake fluid, wait 24 hours (or even more... it doesn't really matter), and remove the paint with an old toothbrush. Cheap and efficient. The toothbrush can be fatal for epic infantry, though...
Brake fluid works for metal as well, although not as well as on plastics... Regular paint stripper should do the trick.
PostPosted: Wed Jan 04, 2006 10:16 pm
For Plastik: Ethanol (ethyl alcohol/ grain alcohol) 24 h
For Metal: Acetone (in Nail polish remover) 30  min.
Happy stripping :p.
PostPosted: Wed Jan 04, 2006 10:21 pm
Quote (Hit-and-Run @ 04 Jan. 2006 (21:16))
For Metal: Acetone (in Nail polish remover) 30 ?min.
Happy stripping :p.
Does it matter what type of paint you're stripping?
PostPosted: Wed Jan 04, 2006 10:39 pm
In Acetone (the only one I've used personally), enamels usually take a bit longer, or even a few scrubbings and re-soakings.
www.darkrealmminiatures.com
PostPosted: Wed Jan 04, 2006 11:11 pm
I have used Pinesol before with good results, but now I use Simple Green since it is non-toxic and biodegradable.  I just put the figures in a jar full of simple green and let them soak in it for a day or longer.  Then just scrub the miniature with a toothbrush.  It works well for both plastic and metal.
-Audrey
My Oubliette: http://audreysoubliette.wordpress.com
Old archive: http://oubliette.tranquility-base.us/
PostPosted: Wed Jan 04, 2006 11:20 pm
Simple green seems to work best.
PostPosted: Thu Jan 05, 2006 9:07 am
@ Dwarf Supreme:
For plastic: Ethanol (ethyl alcohol/ grain alcohol) 24 h
Happy stripping .
Yes ^^. But these solvents do work in most cases. Acetone would melt your plastic figures - use it wisely Luke. :D
PostPosted: Thu Jan 05, 2006 1:14 pm
Check out the last post in here:
EpiComms > EpiComms News > EpiComms Updates > ARCHIVE THREAD: EpiComms Questions and Answers
