Sand and silfloor
 Post subject: Sand and silfloor
PostPosted: Fri Apr 27, 2012 10:09 pm
Quick question for those of you using silfloor tufts...
Do you glue sand on and paint the base before gluing the tufts on? If so, does it stick even though it's not directly glued to the base?
If not, how do you avoid splashing the tufts with paint?
 Post subject: Re: Sand and silfloor
PostPosted: Fri Apr 27, 2012 11:46 pm
only used them a few times, someon reccomended painting base first then using something like hobb-e-tac glue to attach them. I give them a quick spray varnish after to help hold them and seems to stay secured
Epic TOEG mostly done
Terrain log
1/25 dark future
PostPosted: Sat Apr 28, 2012 2:01 am
I completely finish painting and sealing the base, then I put the tufts on.
PostPosted: Sat Apr 28, 2012 2:04 am
I do the same as Dave
PostPosted: Sat Apr 28, 2012 7:27 am
Thanks guys. Now I only have to wait for antenocitis to get early autumn tufts back in stock!
Users browsing this forum: No registered users and 180 guests
