Alterantive for Titan TLD's
 Post subject: Alterantive for Titan TLD's
PostPosted: Thu Mar 22, 2012 9:10 pm
Hi
Sorting through my old Titans to work out what I have for TOEG. I am doing Blood Angels with Titan support. For Titans I am using old Mars pattern figures - i.e. plastic Beatleback Warlords and old metal Reavers and Warhounds. First up I need to model some standard configuration Warlords and Reavers so I can use basic rulebook list.
I will need two Turbo Laser Destructors for each standard Warlord and Reaver that I build. I have enough metal TLD's to model up a pair of standard Reavers. However I don't have enough to model any of the standard Warlords- either the old metal TLD that came with Reaver/Warhound or the new metal TLD that comes with current GW Warlord.
So I need suitable alternative TLD's. I have a few of the old plastic Warlord weapons- I was thinking of using the old plastic laser blaster (from the original plastic Warlord box set) to represent TLD's on Mars pattern Warlord Titans.
For reference the laser blaster is top right in 3rd picture in this thread:
viewtopic.php?f=7&t=19255&hilit=titan+laser+blaster
Do you think anyone would have a problem with this if I turned up with this model at a tournament? (For the avoidance of confusion it would be all or nothing- so all plastic laser blasters would count as TLD's).
Thanks
James
 Post subject: Re: Alterantive for Titan TLD's
PostPosted: Thu Mar 22, 2012 9:19 pm
Can't see any problem it
PostPosted: Thu Mar 22, 2012 9:29 pm
Tournaments count titans with CCW's and Corvus pods as standard config, so I doubt you'll have any problem.
PostPosted: Thu Mar 22, 2012 9:55 pm
Thanks Tim/Ben- I can get gluing then.
James
PostPosted: Thu Mar 22, 2012 9:59 pm
Also if i count laser blasters as TLD's then it makes it easier to comply with any Titan Carapace Weapon restrictions when I get around to fielding variant configurations.
PostPosted: Thu Mar 22, 2012 10:15 pm
Actually, another thing to do would be to ask if anyone has some spare TLD's, for example i think I have some.
PostPosted: Thu Mar 22, 2012 10:24 pm
How well would metal TLD's fit on old plastic Warlord?
What are you after in trade?
James
PostPosted: Thu Mar 22, 2012 10:26 pm
As a different question- what base size are recomended for various Imperial Titans?
From looking at GW website it looks as if the current SG Warlord and SG Reaver are both sold on 50mm round bases. And the current SG Warhound looks as if it is sold on 40mm round base.
Thanks
James
PostPosted: Fri Mar 23, 2012 12:46 am
How about choppping the barrels of one of these and gluing them onto the laser blaster body instead of the original barrels?
http://www.exoduswars.com/Guild-Extermi ... =salesrank
Fits with the idea that FW reavers have triple barrelled turbolasers these days and doesn't look terribly out of place next to the old SG reaver turbo Lasers. Just call them a different pattern.
PostPosted: Fri Mar 23, 2012 12:58 am
Thanks WMN- I don't have any of those and would have to swap for them.
I do like the 3 barrelled look. I had thought that 3 barrels was for laser blaster rather than TLD but I guess the names change over time.
James
My Epic trades list
PostPosted: Fri Mar 23, 2012 2:12 am
Tripled barrelled turbo lasers is indeed what a laser blaster looks like now.
PostPosted: Fri Mar 23, 2012 8:44 am
Thanks
James
I think the base that you see on the SG warlord / reaver are 60mm and slightly thinner than the usual GW bases. Because they're easier to get hold of, I go for the standard 60mm round (i.e. dreadnought base) for reaver and warlord, 40mm round for warhounds
Web Designer / Developer type | erinfreeman.co.uk
Harass me on twitter!
PostPosted: Fri Mar 23, 2012 4:24 pm
Thanks Ben
Perfect- then I can happily use the plastic laser blasters to represent TLD's on the beatleback Warlords. And eventually get hold of some of the new style triple-barrelled ones to represent actual Laser Blasters.
James
My Epic trades list
PostPosted: Fri Mar 23, 2012 4:32 pm
Thanks
James
great- I have several of the new thin 60mm bases that I can use on my SG Raevers, leaving the old style bases with void shield trackers for the plastic Warlords. And I have some 40mm round bases too so that is my Warhounds sorted.
James
My Epic trades list
PostPosted: Fri Mar 23, 2012 4:42 pm
If you want to avoid chopping up Exterminators, then we'll have Behemoth weapons hitting the stores soon enough.
Tom Webb
Users browsing this forum: No registered users and 184 guests
