Post new topic Reply to topic  [ 86 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
The dummy's guide to building a CI
 Post subject: The dummy's guide to building a CI
PostPosted: Fri Jul 15, 2005 9:33 pm
Hi all,
well, here's something I got myself into. The AMTL list I used for getting all worked up to participate in the ToxG 2nd ed included the CI, and this was the very first model I planned - trouble is, the current list excludes it! Nonetheless, I'm now too keen on the idea to let it drop, so - here goes.
A word of warning: my version of the beastie is big, far larger than the old CI, and almost as tall as a Warlord. Mind you, my 'real' CI would have this size - it does contain a LOT of troops. But I realize not everyone will like these dimensions.
In order to make this conversion easy to replicate:
1 - I won't include sculpting (can't do it myself, anyway ?:p )
2 - I'll use only currently available bits (and mounds of plasticard and stuff)
3 - I'll try to keep it as cheap as possible.
There is a baseline to the $ issue, however, and mine is set at 15GBP. An Epic superheavy is cheaper, and built up with plasticard can make a creditable CI - too small for me, though. Several historical tank models (1/76 scale in particular) can be similarly converted. But I'm starting with something available from GW online, so that everyone will be familiar with the material used.
The 15GBP are spent on a 40K scale Rhino. A Chimera or Leman Russ hull would be useful as well, but the Rhino is cheaper ( Chimera = 18GBP, LR = 20GBP). This beastie is 120 mm long, 80mm wide, and 50mm high, so it IS big compared to Epic stuff. The old 40K Rhino is slightly smaller, but equally useful. The Chaos Rhino can be used as well. I dare say assembled 2md hand Rhinos can be found for a relatively low cost, and these too can be modified to CI status.
Anyway, that's it for the first post. Right now I'm jotting down ideas for the conversion. Hope this will work! ?:-:
Back from oblivion (again)?
PostPosted: Sat Jul 16, 2005 12:23 am
[dafrca sits in the front row and opens his note pad.]
:cool:
dafrca
              - Cities of Death, page 59
PostPosted: Sat Jul 16, 2005 1:05 am
Tas
PostPosted: Sat Jul 16, 2005 5:38 am
"He's quite mad, you know ... !"  :laugh:
PostPosted: Sat Jul 16, 2005 7:52 am
Quote (Legion 4 @ 15 2005 July,21:38)
"He's quite mad, you know ... !" ?:laugh:
Yes, but most visionaries are.  :;):
dafrca
PostPosted: Sat Jul 16, 2005 8:40 am
Good grief, a crowd already.... I think L-4 has hit it right on the button :laugh:
PostPosted: Sat Jul 16, 2005 8:58 am
Quote (dafrca @ 16 2005 July,16:52)
Yes, but most visionaries are. ?:;):
dafrca
Sadly, most visionaries are exiled, damned or burnt at the stake.  Their value is only realised much later...   :D
Tas
PostPosted: Sat Jul 16, 2005 9:43 am
Quote (Tas @ 16 2005 July,09:58)
..... exiled, damned or burnt at the stake..... ?
Ah - so that's what's in store for me  :o Better delete Dafrca's post about visionarism then - gulp!  :(  :p
Anyways - to work! Sharpen your pencil, Dafrca. Or get ready to put it away.... here's a pic showing the partly-assembled 40K Rhino, with a partly-assembled real CI and an Epic Rhino for scale. It IS much bigger. It also looks very much like a Rhino.... doh  :p
PostPosted: Sat Jul 16, 2005 9:57 am
So far I've assembled the first 4 stages of the Rhino, omitting the central bulkhead (this has 40k scale detail, and if I leave the rear hatch open, this just wouldn't do) and the front panel assembly. I might add this late ad build over it, but I still have to decide loads of stuff first. Such as:
1 - how to give the brute an Epic feel
2 - how to reduce the Rhiney look
3 - whether to use a Behemoth cannon in a turret (as in the old model) or (as it's fire arc is forward only) to make it fixed and larger in size.
4 - I'm not sure whether to include a ramp at the front (as in the old model). An alternative would be to use the Rhino side doors as ramps - another break from tradition
5 - how to build turrets and guns - I usually rely on my bits box, but having promised to stick to 'easy solutions', my hands are tied. Anyway, I'll work my way out of this...
The pic attached shows the rear ramp with an Epic Rhino for scale - that ramp is begging to be used!
PostPosted: Sat Jul 16, 2005 12:38 pm
ooooo I like classes like this!  :D   How many credits do we get?
my 2cents,
iblisdrax
PostPosted: Sat Jul 16, 2005 12:49 pm
Quote (iblisdrax @ 16 2005 July,13:38)
ooooo I like classes like this! ?:D ? How many credits do we get?
my 2cents,
iblisdrax
The standard 4 credits, Mister Drax; IF you complete the coursework satisfactorily and pass the exam.  :O
PostPosted: Sat Jul 16, 2005 3:38 pm
Good luck you mad man, visionary ! :laugh: And nice :unclesam: Rhino ! :;):
PostPosted: Sat Jul 16, 2005 4:21 pm
Quote (vanvlak @ 16 2005 July,12:49)
my 2cents,
iblisdrax
The standard 4 credits, Mister Drax; IF you complete the coursework satisfactorily and pass the exam. ?:O
I think I had better audit this class, instead of taking it for credit!  :p
PostPosted: Sat Jul 16, 2005 5:11 pm
[dafrca takes notes and draws sketches in his notebook]
OK, following so far...
dafrca
PostPosted: Sat Jul 16, 2005 10:44 pm
Quote (vanvlak @ 16 2005 July,21:49)
my 2cents,
iblisdrax
No no doubt some practical assignments too!  :D
Tas
Users browsing this forum: No registered users and 170 guests
