Campaign Maps
 Post subject: Campaign Maps
PostPosted: Fri Feb 24, 2012 11:08 am
Do any of you guys use PLANETARY EMPIRES to represent planetary campaigns ??
I've just browsed the GW website and come across it for the first time today. Some of the painted examples are quite impressive.
*Note: Apologies if this would be better placed in a different forum section. *
 Post subject: Re: Campaign Maps
PostPosted: Fri Feb 24, 2012 3:09 pm
I've done so in the past. The rules are basic, and need some slight modification toi fit into Epic, but if you're into a map based campaign that is not story driven, they work pretty well.
PostPosted: Sat Feb 25, 2012 2:47 am
I use the "War without End 2011" rules set out by Onyx at the moment, it works fine. The only difference is that there is no physical map (since our copy of planetary invasion is inaccessible atm). You can see the corresponding thread here: http://www.tabletoptreff-hannover.de/fo ... ?f=8&t=921 But beware, German language, some english snippets mixed in.
PostPosted: Sat Feb 25, 2012 6:30 pm
Thanks.
Users browsing this forum: No registered users and 152 guests
