Need Firedragon Falcon Conversion idea
 Post subject: Need Firedragon Falcon Conversion idea
PostPosted: Sat Jun 11, 2005 3:12 pm
I'm trying to make a Falcon Grav Tank look more unique for the Firedragons.
Any ideas?
It's the new style GW metal Falcons. Ones with the turret
PostPosted: Sat Jun 11, 2005 3:28 pm
*** Is it the old Plastic falcon or the newer metal and resin ones? ***
Lextar: It's the new style GW metal Falcons. Ones with the turret
Cheers! :)
PostPosted: Fri Jun 17, 2005 11:40 pm
hmm... no one got any ideas?
I've finished my FireDragon Troupe with two custom made Exarchs.
I've got two more Wave Serpents to paint... then I'm
wanting to do a special Falcon Grav Tank for the Fire Dragons, but not sure what I can really do.
Anyone made a conversion before?
It's the latest GW Falcon Grav Tanks
PostPosted: Sat Jun 18, 2005 1:48 am
Not been done by me. Sorry, I suspect the silance is in a way your answer. You are the first. :;):
Good Luck. Let us know what you do.
dafrca
              - Cities of Death, page 59
PostPosted: Sat Jun 18, 2005 6:45 am
How about adding dragon wings to the model.  An idea...   ???
PostPosted: Sat Jun 18, 2005 8:39 am
hmmm... dragon wings... where can I get dragon wings...
oh well. was hoping to look for inspiration.
PostPosted: Sat Jun 18, 2005 9:22 am
Hi Lextar,
problem is that the new Falcon is such a complete-looking kit there's not much that can be done to it! For example, I modified my old plastic Falcons by adding wings, but that old model had lots of scope for conversion. Ironically, the better a model is, the less there is to fix or change! And then again, the Eldar aren't the easiest race to modify - Orks, Chaos and the Imperium are far easier!
What might work would have to applied on a small scale:
1 - colour scheme - the easy way! - use a very characteristic scheme.
2 - weapons fit - select a turret appropriate for the Dragons and give all tanks the same type, if you have enough.
3 - basing - if you like basing models, place a couple of extra dragons next to a tank
4 - banners: add a thin flagpole at the rear of the vehicle and fit a long, thin streaming pennant to the rear.
5 - markings - apply FD rune transfers (or paint them) on the hull
6 - Drakeskin - apply a thin coat of green stuff over flat areas of hull and inscribe a scaly pattern on them
7 - weapons upgrade - replace one weaon with something suitably long-barrelled, representing a fire-pike type of weapon. It won't have any affect on the game, but will characterise the FD Falcons
8 - fins - add small  fins over the flat parts of the hull, pointing up and appearing continuous to the hull i.e. try to follow, or extrapolate, the curvature, to make them seem part of the wraithbone hull. MAny ways to do this!
9 - make one over the top conversion, mounting a dragon head over the basic hull shape, and use it as a lead vehicle, with the others being merely similarly coloured, or with FD maeks or pennants.
Ok - I've run dry now.... :p
Good luck, Lextar!
:D
Back from oblivion (again)?
PostPosted: Sat Jun 18, 2005 10:24 pm
I see what you mean. Think I'll try modifying the weapons and maybe add some fins etc.
Thanks
PostPosted: Mon Jun 20, 2005 5:33 pm
If you're just looking for fin ideas...
I bought some second hand Wave serpents where the person had cut the "blade" fins off the sides of the Nightspinner hulls and mounted them on the rear platform next to the turrets.  Something similar could give a dragon wing-like appearance to the turret.
PostPosted: Sun Jun 26, 2005 10:44 pm
Now that I finished off Fuegan and painted him, I sorta gone off trying to mod the Grav Tank for him :(
I've made a few changes, but not really happy with it and not how I imagined... *sigh* oh well... trying to paint it now.
PostPosted: Sun Jun 26, 2005 11:48 pm
Hi AM "V", didn't you have pics of a MK.1 Falcon with wings you added on ? The wings were the blades off the SM2 Mega-Gargant's "bow ram". I cut mine off too and glued CinC Dragons Teeth instead.  I still have them in my bitz box !    :;):
PostPosted: Mon Jun 27, 2005 3:41 am
Looks ok to me Lextar - my friend has a falcon I nicknamed 'The Fire-engine' carrying firedragons. Just a fiery paint-job.
PostPosted: Mon Jun 27, 2005 7:47 am
Quote (Lextar @ 26 2005 June,14:44)
Finish the job, paint it up, and let us see it.
Sometimes as the artist, you can become too critical because the vision in your head does not match the outcome perfectly.
Where we will see it for what it is. Often it is better then you may think.  :;):
dafrca
Users browsing this forum: No registered users and 111 guests
