Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2, 3  Next
Removeable Titan Weapons?
 Post subject: Removeable Titan Weapons?
PostPosted: Tue May 31, 2005 8:32 am
I'm about to finish up my titans and I was wondering; do the majority of the people glue them on or just attache them so they can be changed out?
PostPosted: Tue May 31, 2005 9:44 am
Personally I don't do the glue thing, the plastic 'brackets' seem quite sufficient to hold any weapons in place however they do get a bit more 'banged up' that way. I guess this stems from ye olde dayes when a hit to a weapon could be easily represented by removing the weapon.
PostPosted: Tue May 31, 2005 1:54 pm
Hi Guys,
I prefer the removeable-type weapons... :)
My friend Chern prefers permanently-mounted ones.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Tue May 31, 2005 2:34 pm
There was once an article somewhere on how to use magnets to make the weapons interchangeable.
Its a VERY good solution to this.
PostPosted: Tue May 31, 2005 2:48 pm
None of my titans have weapons glued on permanently. I like being able to change the weapons. I do have favorite waepons, but sometimes I like to try different combinations. I use a putty-like substance to hold the metal weapons  in place. Unfortunately, my Corvus assault pod is too heavy to be held in place  :(  , but all the other wepaons stay in place pretty well.
PostPosted: Tue May 31, 2005 3:03 pm
Quote (primarch @ 31 2005 May,06:34)
I agree, Maksim has been playing with small magnets in his force. I have seen others do it with their minis.
If you think you would like to mix and match, then do magnets. If you have a combo you like a lot and do not see yourself changing much, then glue them in place.
dafrca
              - Cities of Death, page 59
PostPosted: Tue May 31, 2005 4:59 pm
I'm a gluer, but that's mainly because of weirdo conversions. :blues:
Back from oblivion (again)?
PostPosted: Tue May 31, 2005 5:51 pm
I'm a gluer as well. I usually try to pose my models a bit dynamically which often means attaching the weapons differently than intended by the sculptor.
Cheers! :)
PostPosted: Tue May 31, 2005 8:17 pm
It depends on the weapons I guess.
My arm mounted weapons normally are glued becuase they are metal. Top mounted ones normally are not.
But then I have so many titans. I haven't found the need to change the weapons  :p
PostPosted: Tue May 31, 2005 11:31 pm
Thanks guys
  okay if i was to use magnets which ones do i get. I've seen an article in WD using earth magnets on 28mm figures; Is that good for titan weapons?
PostPosted: Wed Jun 01, 2005 1:06 am
Glue!
Makes the models seem 'whole' if you know what I mean, more of a model in their own right and less of a playing piece.
www.darkrealmminiatures.com
PostPosted: Wed Jun 01, 2005 2:26 am
Yep glue - if you need a different configuration buy a new titan :) ?Aint that right Primarch :;):
Mind you, I have in the past changed bio-titan, phantom and gargant weapon configs... just rip the old gun off carefully, clean up the join and carefully paint the new one good as new... Obviously with this technique I don't change weapon configurations if I can help it!  :D
PostPosted: Wed Jun 01, 2005 2:34 am
Quote (centurion @ 31 2005 May,15:31)
Thanks guys
? okay if i was to use magnets which ones do i get. I've seen an article in WD using earth magnets on 28mm figures; Is that good for titan weapons?
I believe that is what Maksim is using. I have not tried it myself yet.
dafrca
PostPosted: Wed Jun 01, 2005 10:46 am
Quote (dafrca @ 01 2005 June,03:34)
Thanks guys
dafrca
Not yet tried on Titan weapons, but strong earth magnets used on BFG ships work very well. You should have a look at K&J site:
http://www.kjmagnetics.com/
The discs D1Y1 or (probably better, especially for metal weapons)  D2Y1 should be good ones for your purpose.
PostPosted: Wed Jun 01, 2005 12:42 pm
Definately glue. It gives the Titan a personality and narrative through lots of games.
Users browsing this forum: No registered users and 188 guests
