Green...err Blue Stuff
 Post subject: Green...err Blue Stuff
PostPosted: Fri Dec 31, 2004 10:10 pm
Okay, I got my first tube of Green stuff!  *applause*
So are there any tips, suggestions, what NOT to do with it, etc etc?
my 2cents,
iblisdrax
PostPosted: Fri Dec 31, 2004 11:19 pm
Keep the stuff and the tools wet until you are done. Dont let it dry out.
PostPosted: Fri Dec 31, 2004 11:48 pm
I wouldn't eat it either...
:p
Jimbo
Felix's Gaming Pages
Felix's Gaming Pages Blog
Almost Always Right...
PostPosted: Sat Jan 01, 2005 12:18 am
Quote (Jimbo @ 31 2004 Dec.,14:48)
:p
...but it tastes so good...  :p
dafrca
              - Cities of Death, page 59
PostPosted: Sat Jan 01, 2005 12:20 am
Quote (iblisdrax @ 31 2004 Dec.,13:10)
I have been told layers are your friend. Mix small amounts and build up to what you want. Don't try to do it all at once.
Least that was what I was told.  :cool:
dafrca
PostPosted: Sat Jan 01, 2005 11:35 am
To paraphrase Dafrca, less is best - you can always add more later. And it's surprising how little you need in many cases - don't waste the stuff by preparing loads. A couple of mm length of strip is enough, esp. for Epic cases.
I strongly recommend CS' suggestions about wet tools, as it sticks really well.
Whilst it's excellent for sculpting when still uncured, don't forget it can also be filed down really well when hard. DON'T file it when uncures, you'll only clog your files (painful voice of experience, this). And give it some 24 hours to cure before filing, drilling, undercoating etc.
Enjoy!  :D
Back from oblivion (again)?
PostPosted: Sat Jan 01, 2005 1:13 pm
Keep it very, very wet while scupting....
seriously, spit on it or whatever, but keep it wet and it will do what you want much more easily....
Tas
PostPosted: Sun Jan 02, 2005 10:25 pm
*pokes up head from temporary lurker-dom*
Its also a goodmove to keep it in the fridge (or freezer) if its fresh. It prevents any of it curing in before you use it & gives a better working consistancy.
However, if you bought yours from GW, then its most likely been standing in a warehouse for a few months & its not worth refridgerating it.
*returns to a temporary state of perpetual slumber...... :D *
Paul "TuffSkull" T.
PostPosted: Mon Jan 03, 2005 2:36 am
no, not from GW, different brand, color, same material for less $$$  :)
my 2cents,
iblisdrax
PostPosted: Sat Jan 08, 2005 1:26 am
I hate this green stuff personally, it smells so bad.
Has anyone tried 2-part epoxy putty instead?  I find that much better:  you can smooth it out with water, it lasts a long time, you can apply lots of it in a single layer, you can even cut into in when its semi-set.
CF
PostPosted: Sun Jan 09, 2005 2:33 pm
??? Green stuff was a two-part epoxy putty last time I looked.....
www.darkrealmminiatures.com
PostPosted: Sun Jan 09, 2005 2:38 pm
That was my understanding as well..... ???
my 2cents,
iblisdrax
PostPosted: Sun Jan 09, 2005 4:54 pm
I use MilliPutt so I have few tips.
But keeping your tools damp is a must wat ever putty u use.
If your making something detailed or a complex shape then build in stages.
I find alot of work id easier if done ?when the putty is semi firm. For example if u take a look at my Mirco Fighter youll see either side of the wind-sheild two tubular sections that join. To do this I made ?one bit.. let it semi-firm and then finished shaping it, then built the other bit on top.
Nuf Said.
PostPosted: Sun Jan 09, 2005 6:49 pm
Quote (stormseer @ 09 2005 Jan.,13:33)
Sorry, I thought you guys meant the single tube green stuff by "squadron" brand. ?That stuff I hate.
CF
PostPosted: Sun Jan 09, 2005 8:50 pm
Thanks for all the tips, guys!  And nice instructive pic there Krooza!  Maybe this topic should be pinned, do you think?
my 2cents,
iblisdrax
Users browsing this forum: No registered users and 171 guests
