How Do You Strip 6mm Plastic Infantry?
 Post subject: How Do You Strip 6mm Plastic Infantry?
PostPosted: Wed Nov 24, 2004 3:36 pm
As for subject. The catch is to strip without melting the little tiny bits.
Oh, BTW: I live in Italy. Do *NOT* tell me about this wonderful product you can find at your local Wal - Mart, because the nearest one is 5000 kms away  :p
PostPosted: Wed Nov 24, 2004 3:58 pm
I've been quite successfull using common household Ethanol. Leave thee miniatures sooaked foor a couple of days and it should release most of the paint from the miniature. Use some kind oof a brush under running water to remove the loose flakes of paint. -It doesn't work very well on enamel paints though.
Another methood is to use very hot water. Leave the minis in it for a while; then replace thee hot wather with ice cold water. The rapid change can sometimes cause those flakes of paint to loosen. (This method is NOT scientifically proven: Sometimes it works, sometimes it doesn't.)
Cheers!
PostPosted: Wed Nov 24, 2004 4:45 pm
I think there is a pinned thread in one of the forum's discussing this.
And Magnus, if you decide to go with a product not locally availible, I will personally send you some in Italy!
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Wed Nov 24, 2004 5:02 pm
Hi Magnus,
I built a master post for paint stripping to help you and others out.
Check it out at:
Master Paint-stripping Thread, Metal & Plastic!, Advice regarding stripping models...
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
