Couple of rather random questions...
 Post subject: Couple of rather random questions...
PostPosted: Mon Sep 13, 2004 3:00 pm
Hi,
Been a rather slow painting day, just finishing some bases and details. I've also been throwing around some future ideas, but needs some outside inspiration. Just have a few random questions, if anyone could help me out would be great. :)
1. Any thoughts on how to paint Scout Rhinos for Crimson Fists? Should I just stick to normal colour scheme, or attempt some sort of camo pattern?
2. Does anyone know of any suitable bases that I could attach my spare whirlwind/hunter turrets to? I am thinking of small X shapes (or similar) so that they represent permanent weapon placements, but still fit on a WM base. I've looked around, but inspiration hasn't slapped me yet.
3. Does anyone know which website store makes those 6mm mortars that fit in Infantry stands? Pretty sure it is UK based, but can't think of who it is and can't find right website anywhere.
4. Could anyone provide me with the dimensions of the Forge World Epic road tiles?
Thanks in advance for any help.
Freshmetal.
Blastmarker.com
PostPosted: Mon Sep 13, 2004 3:40 pm
1: Camo can look good but of course any specific ideas would haver to depend on which type of terrain boards you are playing. A word of advice though is to leave some panels or doors your original Chapter colour to distinguish them as Marine Rhinos and not something in use by the Guard.
2: Hmmm... A simple X shape should be pretty easy to construct from strips of plasticard of even plastic spure. Add a square or round piece of plasticard at the ends for "feet". Alternatively look arround for the bases of 6 or 10mm models of WW2 88mm AAgun platforms.
3: GHQ? I'm not sure if they are UK based but they produce a wide range of 6 and 10 mm stuff http://www.ghqmodels.com/M/index.htm
4: Argh.... This came up recently on the SG site but I can't remember specifically... maybe 7 cm square...
Cheers!:)
PostPosted: Mon Sep 13, 2004 4:00 pm
Camo or tactical colors (but you all knew I was going to say that !).  And the GHQ site has some great models all "camo'd up" ! :;):  As far as mounting your extra turrets, GHQ stuff may be a little small, I'd check the Reaper site.  But W/M is correct on all points, something like a WWII 88mm gun carriage, just like F/W makes !      :;):
PostPosted: Mon Sep 13, 2004 4:34 pm
Not sure about the other questions but regards to Hunter/whirlwind turrets I mounted mine on plastic rhinos with the rear doors shaved off, so I ended with the 4 lead whirlwinds and 4 'plastic' hunters.
PostPosted: Mon Sep 13, 2004 5:04 pm
Quote (Freshmetal @ 13 2004 Sep.,07:00)
Look at Brigade Models. They have a small Mortar that has a round base.
Their URL:
http://www.brigademodels.co.uk/
What you want is: SF300-5001, Infantry Mortar @ ?0.10 ea.
dafrca
              - Cities of Death, page 59
PostPosted: Mon Sep 13, 2004 5:08 pm
You could make your own from plastic rod as well- cheap, dead easy and quick too.
www.darkrealmminiatures.com
PostPosted: Mon Sep 13, 2004 5:24 pm
Hi,
Thanks all,
RE: scout Rhinos: I think I'll use the camo idea then, with grey/blue/black, as they're city based. I shall try some test ideas first however. Thanks all.
RE: hunter/WW turrets: I have some of the FW Earthshaker platforms, but they're a bit large for the turrets, and I was thinking of a more permanent looking structure than those. I shall attempt to make some, but will keep an eye out for alternatives.
RE: mortars:
@dafrca: Thankyou, that was exactly the one I was thinking of. I just couldn't remember who made them. Thought it could be GZG, but you've found it. Thankyou.
RE: F/W tiles: Thanks WMN, I shall take a look on the SG forums to double check, but knowing roughly what size they are lets me know how many I might need. :)
Thankyou all, any other thoughts are welcome. :)
Freshmetal
Blastmarker.com
PostPosted: Mon Sep 13, 2004 7:33 pm
Hi FM,
I'd make them the standard Crimson Fist midnight blue. And, by the way, I AM THE CRIMSON FISTS GUY!
I would use small "X's" from spare sprue first, but you can get bases from many places. Brigade will sell you their bases without the AA turrets if you want. Scotia will also part out modern microarmor bases for your pieces if you want.
I mount my turrets on small rare earth magnets now so that all of my turrets are now interchangeable. It's soooo cool!
Another option is to mount them on bunkers or Epic ships. The small FW Epic bunkers would probably look good with armament. I have a ton of bunkers for my WWII and modern microarmor armies. I should have thought of this for myself!
I like to convert the plastic WW Rhino chassis to regular transport Rhinos to have variety. I chop them up to make all kinds of special SM kit such as recovery vehicles, water tankers, fuel tankers, engineering vehicles, command Rhinos, sensor or radar Rhinos, flatbed Rhinos, etc.
Brigade.
Although, Scotia's neutral equipment line looks much nicer although it's a tad more expensive (shell out a few more coins of change!).
I posted this at the official forums, but:
3"x3" & 3"x6" or roughly 75mmx75mm & 75mmx150mm
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Mon Sep 13, 2004 9:42 pm
Hi,
Thanks Maksim, that's what I wanted to know. I saw the Brigade AA gun bases and think they'd be ok, so I shall get hold of some soon and post pics.
One more thing (other than to point out that I am the CF guy)...
Pictures, pictures, pictures!!! (bet you knew that was coming)
Freshmetal
Blastmarker.com
PostPosted: Tue Sep 14, 2004 2:21 am
Quote (Freshmetal @ 13 2004 Sep.,09:24)
RE: mortars:
You are welcome. I have thought of ordering some for myself, but at this point I do not need them. I have too much to finish now.  :p
Of course there is that little IG commander in the back of my head who swares he needs 32 or so.  :;):
dafrca
PostPosted: Tue Sep 14, 2004 2:24 am
Quote (MaksimSmelchak @ 13 2004 Sep.,11:33)
Brigade.
Yep, as I posted above, I was sure it was the one he was talking about.
I do have to agree; Scotia has some great "extras" for many uses: mortars, small boats, bikes, and other such. However, good luck getting it. I have not had much luck of late.
Where do you get your Scotia?
dafrca
PostPosted: Tue Sep 14, 2004 2:31 am
My friend Rob Mako and I ordered a big bunch of stuff (mostly jet aeroplanes and ordinance) directly from them in England.
It's very hard to find in regular stores. You pretty much have to direct order it.
If you decide to do so, let me know, Daniel. I can advise you on good codes and I want a little more myself.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Mon Sep 20, 2004 3:42 pm
Hi,
Another random Q:
I built a Warlord Titan (Beetleback), with a power fist, a laser blaster arm, two rocket launchers on the carapace (Mk1 Whirlwind turrets) and a hunter missile launcher (may remove, not sure). :) Anyways, does anyone know what "pattern" the beetleback Warlord is?, and what the heck I should name this "configuration?"
Freshmetal
Blastmarker.com
PostPosted: Mon Sep 20, 2004 4:04 pm
Based on SM1/AT1, sounds like a Death Bringer variant ... :)
Users browsing this forum: No registered users and 129 guests
