Necron Proxies
 Post subject: Necron Proxies
PostPosted: Mon May 23, 2011 5:48 pm
Hello
I am gathering proxies for a Necron army right now. I am following the classic path for most of the units (e.g. Edenite for infantry, Otterware for vehicles). I am missing a few more models though. Any ideas?
Harvesters: I am thinking about using Firestorm Armada Dictatorate ships for all three Harvesters (Abattoir, Barque, Orb):
Barque (pretty much as is):
Abattoir (pretty much as is):
Orb (as is but with a marble or something added on top of the round exhaust in the middle):
While these models don't fit 100% into the GW Necron style, they would at least be internally consistent (i.e. all Harvester have the same style). Thoughts?
I am also looking for a good proxy for the Deceiver. The two obvious options are both to tall for me (40k model, Warhammer Spellsinger). I am using the beautiful Nightbringer proxy from Apo so I need something in the same size class (about 15mm tall). Does anybody know a 15mm model that looks similar enough? Some kind of Wood Elf mage or Wardancer type in 15mm?
cheers
Helge
My blog and armies: http://wargamingworkshop.wordpress.com
 Post subject: Re: Necron Proxies
PostPosted: Mon May 23, 2011 6:14 pm
Wow !!! I like'm !!!
PostPosted: Mon May 23, 2011 6:38 pm
Good ideas all - I say go for it.
PostPosted: Mon May 23, 2011 7:29 pm
They look decent enough as easy proxies but there's a size issue - your proposed DC3 war engine is half again as big as your proposed DC8 war engine.
Someone on the forum is making a barque proxy to cast, you may want to work on the other stuff first and hopefully by the time you finish them that'll be available.
PostPosted: Mon May 23, 2011 8:11 pm
Ah, overlooked the size bit. Maybe I could use one of the smaller Directorate cruisers or frigates as the Barque instead?
Any idea on the Deceiver proxy?
This is a long range project. I am going to devote 2011 to model aquisition so painting won't start before 2012. Squats, Eldar, Tyranids and/or AdMech are on the list fo 2011 painting.
PostPosted: Mon May 23, 2011 9:46 pm
Talking Apoc into making one? I imagine quite a few of us would like to see one (me included).
PostPosted: Tue May 24, 2011 8:57 am
I'm in need of a Deciever proxy as well. I was planning on converting one, but if there's nothing really fitting out there a custom-made proxy would be welcome!
Users browsing this forum: No registered users and 141 guests
