PVA glue masking
 Post subject: PVA glue masking
PostPosted: Wed May 11, 2011 3:47 pm
Has anyone tried using PVA glue to mask details when applying a sprayed paint coat?
Any luck with this? worth a try?
 Post subject: Re: PVA glue masking
PostPosted: Thu May 12, 2011 4:08 am
I would think that rubber cement would be easier to work with and clean off a model.
PostPosted: Thu May 12, 2011 4:25 am
why not just use liquid latex mask?
PostPosted: Thu May 12, 2011 4:33 am
I'm guessing standard elmer's glue is cheaper, and it's quite water soluble.
PostPosted: Thu May 12, 2011 11:37 am
worth a try. report back.
PostPosted: Thu May 12, 2011 11:44 am
That was kind of how I was answering my own question. Next time I have some time to tinker...
But no reason to double somebody else's valuable tinkering.
PostPosted: Thu May 12, 2011 2:05 pm
It is water soluable, but not if it is covered with a layer of acrylic...
I suppose you could scrape the paint off an then dump it in water. I would find the extra dollar or two spent on the latex/rubber cement would be well worth it when compared to the extra time and effort.
PostPosted: Thu May 12, 2011 2:51 pm
True enough, it's not as if I'm not spending dollars on ArmyPainter pigmented sprays, etc. anyway.
I suppose part of the other attraction for me for PVA glue masking is that it is fairly 'kid-friendly,' meaning that I can involve my 3-year old in some portions of the painting process, rather than having to create an 'exclusion zone.'
You're right about the issue of solubility, it'll be one of the interesting things to text out: just how impermeable is the layer of acrylic. It's a good reminder to test on a second-class mini.
PostPosted: Thu May 12, 2011 4:07 pm
Rubber cement is very kid friendly. I used to use it in grade school all the time.
Users browsing this forum: No registered users and 177 guests
