Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
Two-piece molds
 Post subject: Two-piece molds
PostPosted: Tue Apr 05, 2011 10:58 pm
What do people use for setting models into to pour the first half of a two piece mold?
Ideally I'd like something reusable. The employee at Blick's suggested a product called Earth Clay, but I'm wondering if something like a bake-to-set modeling clay would work.
 Post subject: Re: Two-piece molds
PostPosted: Tue Apr 05, 2011 11:03 pm
I don't do two part moulds. I suspend the model, pour silicone all around it, then physically cut the mould plane with a knife.
PostPosted: Tue Apr 05, 2011 11:04 pm
Doesn't that run the risk of damaging the master? My understanding is silicone has a mold life of around sixty casts, max. How do you suspend it?
PostPosted: Tue Apr 05, 2011 11:08 pm
Ohhh Fancy!
PostPosted: Tue Apr 05, 2011 11:12 pm
Yeah, I guess. Try not to stab it. :-)
Depends on the model. Sometimes more, sometimes less.
I build a rig, that will act as the feed lines for the resin when it is removed from the mould.
PostPosted: Tue Apr 05, 2011 11:13 pm
E&C is right that one-part moulds are generally better, but if you really insist, Play-Doh can be used to sink the models into to pour the first half.
PostPosted: Tue Apr 05, 2011 11:15 pm
Seems possible. Could be too risky with models that can't simply be reprinted (i.e. handmade).
Do you have a pic of a rig? I'd like to see how you do it.
PostPosted: Tue Apr 05, 2011 11:23 pm
Me too!
PostPosted: Tue Apr 05, 2011 11:26 pm
Rigs generally look like sprues, really.
Here's a rig I just built for some mini tanks. I'll stick it to the side of a moulding box, then cut it out later.
PostPosted: Tue Apr 05, 2011 11:29 pm
Oh, I see. So you just glue that to the side of the box. What would you do for a model that has no sprue? I'm going to be attempting to cast my Warbarques.
PostPosted: Tue Apr 05, 2011 11:30 pm
I'd make a sprue. :-)
PostPosted: Tue Apr 05, 2011 11:33 pm
Helpful and sarcastic! Super.
Slightly worried about the amount of contact with the box required for a model the size of the 'barques, but I'll experiment.
PostPosted: Wed Apr 06, 2011 12:03 am
Sounds interesting and there is a shortage of them, what do your Warbarques look like?
PostPosted: Wed Apr 06, 2011 12:09 am
This.
This particular one was a commission model that's since moved to it's final home. However, the design is pretty simple, and I'm planning on doing only one more and casting it for the two more I need for another local player, and anyone else who wants one. May also do another Tomb Complex:
Finally, the last of the two local comissions are Abbatoirs. Probably get a model I'm happy with and dip it in rubber as well...
PostPosted: Wed Apr 06, 2011 12:18 am
Looks good! I reckon I'd be interested in 1-2 of those :)
Users browsing this forum: No registered users and 130 guests
