Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 26 posts ]  Go to page 1, 2  Next
Titan bits - Banelord conversion.
 Post subject: Titan bits - Banelord conversion.
PostPosted: Sat Oct 18, 2003 8:35 pm
I just did a banelord conversion. ?I scratch built a chainfist for it. It was inspired by the one tuffy did for his warlord. ?Here are a few pics of it. ?I'm very pleased with the way it turned out.
I made the the forearm and upperarm using plastruc strips. ?I made resin copies of a shin plate for the chain guard and the upper arm plate. The chainsaw itself is .02 evergreen sheet. ?I stretched sprue to make the wiring and then dressed it up with bits from my spare parts box.
This is the powerfist. ?I used putty and plastruc to change the proportions of the arm so it looked better on this model. I also added a bit of resin plate.
Omnia Exeunt In Mysterium
meng...
PostPosted: Sat Oct 18, 2003 10:37 pm
Hmm... your pictures aren't showing 'Meng- just that nasty red X that seems to get everywhere.. :;):
www.darkrealmminiatures.com
PostPosted: Sat Oct 18, 2003 10:49 pm
Quote (stormseer @ 18 2003 Oct.,22:37)
I'm viewing them fine 'Seer....  :l
Nice work Meng - glad I gave you an idea - you put a lot more work into it than I & have pulled off a far better mini as a result - Great work!
I like tha chain addition as well - I hadnt noticed that in the competition entry photo.
One question - why the preference to stretch sprue rather than use plastic rod or wire?
Paul "TuffSkull" T.
PostPosted: Sat Oct 18, 2003 11:15 pm
...Bah... still nothing.. wonder why... :angry:
PostPosted: Sat Oct 18, 2003 11:29 pm
All I am getting is red crosses. Strange, I had a good look at them earlier as well!
They are rather excelent conversions though. How exactly do you make a resin copy and what do you need?
Chris
Chris
PostPosted: Sat Oct 18, 2003 11:38 pm
I think it's the server stormseer.
Sprue stretching is a technique I picked up doing scale models. ?I can stretch a sprue to the thickness of a hair, so I can get sizes you can't get in rod stock. ?It's plastic so I have a variety of choices of glues I can use, unlike wire. ?I also tend to hold on to all the sprues from my model kits so it's cheaper for me to dig into my sprue box than it is for me to go out and by rod stock.
It's a really good technique to pick up.
As to the casting, I used dental alginate to make a mold of the shin plate and acryllic resin for the casting.  I attached a small piece of sprue to the backside of the plate. This allowed the edge of the wrap around portion of the shin plate to rest flush on the bottom of my mold box.  I poured a small portion of Alginate in, just enough to come up flush to the top edge of the shin plate.  I let this set up. Then I sprayed a little PAM cooking oil on it to act as a release and poured the second half of the mold.  When this set I had a small two piece mold of the shin plate.  I poured about 6 plates and made the arm.
meng...
PostPosted: Sat Oct 18, 2003 11:47 pm
Quote (seekermeng @ 18 2003 Oct.,23:38)
I shall have to try and do so then!
I've never had any luck getting a length of sprue to anything that resembles an even size though, even just for a few mm. More practice I guess!!
You realise if you keep giving me tips, I wont need you to make any more vehicles for me....  :p
Paul "TuffSkull" T.
PostPosted: Sat Oct 18, 2003 11:59 pm
Hehehe, I actually think you don't need me anyway, so I'll give you a tip on stretching.
Rotate the sprue over the flame until it bulges slightly, this is a sign that the spue is the right temp.  If it is too hot or too cool it will break.
meng...
PostPosted: Sun Oct 19, 2003 12:31 am
Quote (seekermeng @ 18 2003 Oct.,23:59)
Rotate the sprue over the flame until it bulges slightly, this is a sign that the spue is the right temp. ?If it is too hot or too cool it will break.
Tip noted - many thanks Meng!
P.S. - Your 'Raider is 1/2 done and I'm itching to start on either the massive Rhino or the comms one as my next piece for the force - thanks again for those!
Paul "TuffSkull" T.
PostPosted: Sun Oct 19, 2003 12:56 am
Nope...I'm not getting the pics either  :(
Sounds intriguing though.  So if you have generated molds you could potentially make more for interested people then ? ???
Tas
PostPosted: Sun Oct 19, 2003 1:39 am
Quote (Tas @ 19 2003 Oct.,00:56)
Nope...I'm not getting the pics either ?:(
Sounds intriguing though. ?So if you have generated molds you could potentially make more for interested people then ? ???
Potentially, probably so & I know many would be interested.  Except by doing so publicly he'd be publicly breaching GW Copyright & IP, so it would never be discussed on this board, would it  :blues:
Paul "TuffSkull" T.
PostPosted: Sun Oct 19, 2003 3:35 am
I can also see the pictures, which by the way are excellent!
Wonder conversion, I love the chainfist!
PostPosted: Sun Oct 19, 2003 3:52 am
Great job !  Even though I'm not a fan of Titan C/C weapons, they look very good ! :D
PostPosted: Sun Oct 19, 2003 10:48 am
Quote (TuffSkull @ 19 2003 Oct.,10:39)
Potentially, probably so & I know many would be interested. ?Except by doing so publicly he'd be publicly breaching GW Copyright & IP, so it would never be discussed on this board, would it ?:blues:
True- quite right and thankyou for pointing out this faux paus.
Meng if you were to PM me on another compeltely seperate issue though maybe an agreement could be forged ?
PS Still cant see the pics
Tas
PostPosted: Sun Oct 19, 2003 1:31 pm
SO how do you make a resin copy? What do you need and how long does it take? Just out of curiosity...
Chris
Chris
Users browsing this forum: No registered users and 131 guests
