Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 14 posts ]
Ork River Monitors
 Post subject: Ork River Monitors
PostPosted: Mon Oct 27, 2003 10:59 pm
Though I have posted these in the following thread they really belong in this area of the forum so there they are for those who aren't going to read the other thread as they may think it is about something else...
These models were made with some SDD 15mm and 20mm Vietnam Riverine Craft.
I added Pulsa Rokitts and BattleFortress turrets as well as Buggy Gunners.
It was too clean to begin with, so I added metal "cladding" to the sides to have a "gargant" look to the sides of the boats.
These are unfinished...
Heavy Ork River Monitor
...but when they are finished those 'umies on dem surfboardz better wotch out
:D
Jimbo
Felix's Gaming Pages
Felix's Gaming Pages Blog
Almost Always Right...
PostPosted: Mon Oct 27, 2003 11:00 pm
Light Ork River Monitor
will finish them one day...
Jimbo
PostPosted: Tue Oct 28, 2003 9:54 am
They very are nice, good job.  I do see what you mean by clean, and think they still are a little.  Is there anything else you could add/take away?
PostPosted: Tue Oct 28, 2003 11:55 am
rivets
is what they really need (and though I had the plastic rod, I didn't have the paitence).
Jimbo
PostPosted: Tue Oct 28, 2003 11:52 pm
What technique would you use to simulate these rivets?
PostPosted: Wed Oct 29, 2003 3:27 am
Jimbo,
I absolutely love them. You da' Orky Genius!
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Wed Oct 29, 2003 8:25 am
Unbelievably good job! I love the riveted, irregular hull plates and patches. The Essence of Orkyness! Way to go, boss mek! :cool:
Have you cosidered adding a ram to the front?
PostPosted: Wed Oct 29, 2003 9:57 am
Quote (primarch @ 28 2003 Oct.,22:52)
take some plastic rod
ands then slice small slices off it and stick them onto the hull
the issue is really which glue do you use and how to stop them all melting or sticking to your fingers
Jimbo
PostPosted: Wed Oct 29, 2003 10:14 am
It is tricky.  I simply use superglue.  I use a cocktail stick to dab some glue to the location where I want the rivet, and then with a very sharp pointy scalpel, lightly press the rivet with the point.  It should pick it up.  When you press it against the glue, the surface tension/stickyness should be greater than the scalpels.  And it comes off into place.  Hands nice and free.
PostPosted: Thu Oct 30, 2003 2:00 am
Cool trick, I dont think I would have thought of making rivets that way.
Almost easy enough for me to try....almost. :)
PostPosted: Thu Oct 30, 2003 8:18 pm
Another good rivet technique is to use gel superglue and a straght pin.  Lay out your rivet pattern, use the pointy end of the pin to pick up a little dab of glue and touch it where you want the rivet.  If you keep pin clean you can lay down very uniform rivets.  When all our rivets are down hit them with a bit of excelerater then give them a quick swipe with a bit of fine sand paper.  presto
Omnia Exeunt In Mysterium
meng...
PostPosted: Fri Oct 31, 2003 9:01 pm
Are those comparable in scale to the MoW ships?  I ask because an ork MoW hull might make a good starting point.
PostPosted: Sat Nov 01, 2003 9:47 am
no they are way bigger (and thus more in scale).
A MoW ship is approx 4cm in length, whereas these are between 6-9cm.
The guns and turrets are from GW models which should give you an indication of size.
Jimbo
PostPosted: Wed Apr 14, 2004 1:24 pm
This thread has been archived.
Users browsing this forum: No registered users and 131 guests
