Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 31 posts ]  Go to page 1, 2, 3  Next
A.V.A.C "Seeker" Attack and recon craft
 Post subject: A.V.A.C "Seeker" Attack and recon craft
PostPosted: Fri Oct 24, 2003 5:07 am
As mentioned in a previous thread I've decided to do a Casting article for Incoming. ?The articles progresses slowly, but the model is done. ?I thought I'd give you a peek at the completed first casting.
(the pic turned out kind of dark)
This is basically a test cast. I plan on two vesrions. ?One with a gattling type gun and one with some sort of intelligance package. ???
Omnia Exeunt In Mysterium
meng...
PostPosted: Fri Oct 24, 2003 5:18 am
Very Nice !  Looks a little like the ones used in Vietnam !  :)
PostPosted: Fri Oct 24, 2003 6:22 am
That's one of the problems in doing scratchbuilts. ?If you want to build something practical and functional looking, you can bet something similar already exists. ?So a lot of what you do looks derivative.
meng...
PostPosted: Fri Oct 24, 2003 6:53 am
Wow!  :O  How did you do the windows?
PostPosted: Fri Oct 24, 2003 8:01 am
I cut five 1mmx1mm strips of sheetstock.  2 across the top and 3 down.  I glued them to the front face of the upper hull.
The windshield wipers are 1/2mm wide pieces of sheetstock. (these came out amazingly well on the cast dupe)  I painted the windscreens gold then washed them with a thin amber glaze.
meng...
PostPosted: Fri Oct 24, 2003 11:31 am
That is fantastic. I am another hovercraft fan, and I have been thinking about outfitting an Epic army with more conventional hovers.
PostPosted: Fri Oct 24, 2003 11:52 am
Quote (CyberShadow @ 24 2003 Oct.,11:31)
Superb work Mr 'Meng. If you can cast these into a companies worth or so they would look awsome as a chimera replacement for a mech. company.
Makes me want to get back into making things for WETepic, but I think I have enough projects on the go for the moment!  :D
Keep it up, and make sure to keep us all informed of your progress.
Paul "TuffSkull" T.
PostPosted: Mon Oct 27, 2003 4:21 pm
Here is the rough casting of the finalized attack version of my avac.
I am planning, tentatively, to do a small production casting of about 60 of these some time next month.  I plan to sell them as three packs.  I'll provide more details when I get it all worked out.
I also finished and submitted my casting article so keep an eye out for it in Incoming .
meng...
PostPosted: Mon Oct 27, 2003 4:43 pm
Again, very nice modeling !  You should be able to sell those easily to Epic players.
PostPosted: Mon Oct 27, 2003 5:21 pm
I would be interested in getting some of them! They would make cool alternatives for Chimera's in Mechanised forces.
Are you planning on making any variations of these, like a battle tank version?
Please update us when some are avaliable!
Chris
Chris
PostPosted: Mon Oct 27, 2003 11:20 pm
The model is very clean and good looking.
Excellent job!
PostPosted: Tue Oct 28, 2003 12:04 am
I hadn't thought of making any variations.  I was considering doing some with no hatches or weapons.  Sort of a conversion base model.  So a person could do what they will with them.
meng...
PostPosted: Tue Oct 28, 2003 12:51 am
Yeah that would be cool. Stick a Leman Russ hatch on their and off you go!
Also, what are the production costs of a model like that? And could you take a pic of one next to, say a Rhino, so we have a sense of scale?
Chris
Chris
PostPosted: Tue Oct 28, 2003 1:57 pm
Here is a pic next to a rhino.
As for production costs, I'm not sure yet.  I'm going to do them in poly-resin to help keep my cost down.  I am going to have to use 2-part RTV for the molds, so between that, the resin and a few other small things I'm looking at about eighty dollars in start up material.  I won't be able to figure a unit cost until after the casting is complete.  I'm not looking to make a killing on these.  The price should be fairly cheap.  I am actually doing this run to try out a few new techniques and toys I've picked up.
meng...
PostPosted: Tue Oct 28, 2003 11:54 pm
Once you feel confortable making 6mm vehicles I really need to talk to you to commision a couple of things for me.... :;):
