Precise dimensions of Epic bases
 Post subject: Precise dimensions of Epic bases
PostPosted: Thu Nov 25, 2010 11:30 am
I'm on the verge of ordering some sheet magnets to magnetize the bases of my army (for ease of storage & transportation). I still have a lot of infantry on long bases and some tanks on 40x20 warmaster bases. I was wondering about the precise dimensions of the "long" infantry bases, at the widest point (where it's touching the table).
I'd say 12mm x 40mm, but I'm not quite sure.
Do anyone know the dimensions from the top of his head ?
 Post subject: Re: Precise dimensions of Epic bases
PostPosted: Thu Nov 25, 2010 11:36 am
I believe it's 40mm x 12mm as you say.
PostPosted: Thu Nov 25, 2010 11:47 am
I order some pre-cut magnets from Litko. The 10mm x 40mm. The are little short and pinch to wide.
I'd say maybe 12mm x 39mm ;)
Link ---> http://www.litkoaero.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=LAI&Category_Code=MB
Just click on a shape then size and scroll to see options like Plywood base, Acrylic, Magnet, Flex Steel Etc...
PostPosted: Thu Nov 25, 2010 2:38 pm
Thank you all ! finally I have opted for sheets of adhesive magnets, because they are thinner (0.85mm) and as I will end with quite some variety in my bases (notably round bases for my eldar army and my new marines).
I Think these A4 sheets will be easy to work with.
The best source for magnets I know is http://www.first4magnets.com (for Europe, they're based in the UK).
The prices are like 1/5th of the first site I ordered from, and they have an incredibly wide range, including some 0.5mm thick magnets, not so easy to find elsewhere.
I even picked up some "toy" magnet cubes to use as semi-geeky gifts for Christmas :). Kept a copper red one for myself of course :P
I used 2mm diameter, 1mm thick magnet, so far they are perfect for resin titan weapons (They even keep some poseability with FW-like ball joints), but i got some other sizes to experiment other stuffs as well. The 6mm diameter/0.5mm thickness will be the perfect stuff for my 6mm Space hulk ;D
PostPosted: Fri Dec 24, 2010 1:32 am
I used Litko magnets to cover the bases of infantry I already have.
I use www.shogunminiatures.com for new bases, because they are cheaper than bases+magnets bought individually.
Users browsing this forum: No registered users and 175 guests
