Evergreen Plastic Channels - Conversion Idea
 Post subject: Evergreen Plastic Channels - Conversion Idea
PostPosted: Wed Jul 23, 2003 11:11 pm
Just went to the hobby shop and bought some Evergreen 2.5mm & 3.2mm plastic channels.
- The 2.5mm fits perfectly over the F/W Leman Russ/Destroyer/Thunderer models' tracks and can be easily cut and bent to shape to cover the exposed tracks, like "real" AFVs.
- The 3.2mm fits over the F/W Chimera, Basilisk, etc., tracks but would require some cutting and filing of the models because of the detail and tracks were molded too close to the hull, so I won't do those. ?
- However, the 3.2mm will fit on most of the G/W Epic Imperial models tracks (SM1/2 & E40K). It should fit on most of the Land Raider models, but may require some filing of the top of the tracks. ?
- Why Bother you say ?! Well I'll probably only use the 2.5 on the models I mentioned above, as they are MIB, everything else I have that is finished will stay as is.
- And it's an easy "fix". And I guess I always thought (after serving in 3 Mech Bns), that the exposed tracks were kind of "goofy", for many reasons.
-?I know, many of you say, well it's Sci-Fi, but as I have said before, just 'cause it's Sci-Fi, it does not have to be "goofy!"?:;):
PostPosted: Wed Jul 23, 2003 11:21 pm
AAAaargh!!! ?
This was supposed to be under Epic 6mm not Dry Dock!!! :angry: ?
Doh!!! :( ?
Where's Maksim, when I need him??! :l
PostPosted: Thu Jul 24, 2003 1:27 am
The moderator can switch it, or Cybershadow.
PostPosted: Thu Jul 24, 2003 2:04 am
Good stuff L4!  I too have always had a bit of a problem, but despite having thought about it, never got around to doing anything about it...
Tas
PostPosted: Thu Jul 24, 2003 3:06 am
Legion-4,
I just switched it. I was out today with a little community service.
Take care and Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Thu Jul 24, 2003 3:27 am
I love evergreen.  I try to keep a huge variety on hand.  For epic modeling one of my favorite products is .02 strip.  I also like their rod and tube variety packs.
Used to be they would send you a free sample if you wrote and asked, but I don't know if that is still the case.  I need to check my latest fine scale modeler for their ad and see.
Omnia Exeunt In Mysterium
meng...
PostPosted: Thu Jul 24, 2003 4:27 am
WOW!!! ?
Like magic!!!
It's under Epic 6mm!!! ?
Thanks for making this happen, Maksim !!! :laugh:  My buddy finally decoded your reply, but again, I could not see it, I could only see the quote ... more Web weirdness ... ???
Users browsing this forum: No registered users and 244 guests
